16.9 - Keeping behind the bars
I shot some footage yesterday at an intersection looking down from a bridge and my tripod wasn't quite level, so I thought I could level the horizon line in FCP by tilting the footage slightly to the left but it moves the black bars also, so I have to reshoot the scene.
Colour correction, the smoke effect, all these are outside the bars also - and if I want to enlarge/zoom in on footage then of course the bars dissapear out of shot. Is there a way to edit footage without affecting the bars without shooting or editing in a different aspect ratio? |
Re: 16.9 - Keeping behind the bars
So you shot in Standard Definition with a black bar overlay to give the impression that you shot widescreen?
In post drop an image of black bars on top of your source after you've applied the filters and effects you want to use -- if you are rotating the source image you will also have to zoom it a little to prevent the original bars from intruding in the new image -- there are masks available that conform to the 16:9 appearance that you can use on a 4:3 image, or you can build one yourself pretty quickly. HTH GB |
Just get rid of the black bars, tilt and zoom it in a little bit, that will fix it without the hassle of re-shooting it again, but in doing this you loose a little bit in resolution. So it's always better to get the proper level while on the shoot.
It's practice footage as I'm about to start work on a website video for a local food delivery company and it's my first job (shooting and editing) since investing in professional equipment and software so I need to make sure my settings are correct before I start editing it. The last job I did was just shooting footage for an editor in Switzerland and the default camera setting was the same as what he requested so I'm confident I'm shooting in the right setting. I just didn't expect the black bars to be affected by colour correction and all the other effects. |
You shouldn't have black bars at all -- you shot 16:9, there are no bars and no room for bars -- so something in your description is off. Have you imported 16:9 HD footage into an SD 4:3 timeline? Why are you looking at anything in a 4:3 frame?
You don't need to reshoot anything if you shot 16:9 HD -- so take us through step by step what you shot, how you imported it, what your FCP settings are ... Cheers, GB |
I've never changed my camera settings in the 5 months I've had it, my FCP settings upon Easy Setup view are:
Format: (all formats) Rate: (all rates) Use: Custom Setup Sequence/Capture preset: DV NTSC 48 kHz Device Control Preset: Firewire NTSC Playback Output Video: Digital Camera Desktop Preview - Main Playback Output Audio: Firewire DV Edit to Tape/PYV Output Video/Audio: Same as Playback I discovered that pressing command 0 brings up a screen settings option but no idea which one I should be on. However my settings for that are as follows: Frame Size - 680 x 480 NTSC 4:3 Pixel Aspect Ratio: Square Anamorphic 16:9 (BOX UNCHECKED) Field Dominance: None Editing Timebase: 30 QUICKTIME VIDEO SETTINGS MPEG-4 Video I have not yet mentioned that my Quicktime quality when full screen is questionable so I also need to find out what the optimum setting is, though for small screen it looks fine. Hope this is the info you need, thanks for your assistance Geoff. |
Well, your project settings are Standard Definition and DV codec -- neither of which you are shooting.
If I assume your transfer from your camcorder is proper, then you should have files on your HDD that are both High Definition and in a different codec (sorry, I'm not certain what codec your camcorder uses) -- in which case you can simply drag one of the clips onto a new timeline & FCP will say something like 'would you like to change your project settings to match your source material?' and you can say 'yes' and all will be good. If you've done something odd on capture so that your source material has been converted to SD DV ... well, we'll have to step through how you are getting your material from your camcorder to your computer. But you shouldn't be downgrading your material to SD DV, you shouldn't be working in 4:3 with 16:9 source, and your output is compromised because of that. Cheers, GB |
Double post!
I understand this is not a case of straightforward question and answer and I'll probably have to visit a fellow editor who I don't know that well but who can show me first hand. That said, I am very grateful of the advice so far. |
Sorry to say it sounds like your problem starts with your transfer from your camcorder. A few minutes with those that use the same system will likely lead to the answer -- I won't volunteer here as it is not a camcorder I use ... But I am quite certain you are doing it wrong!
You are shooting an AVCHD format with a 16:9 ratio, you should be able to use log and transfer to bring that in and edit, perhaps you will need to convert to an interim format like ProRes -- but there is no reason to be working in SD DV. As for checking the 16:9 box, that is intended for anamorphic 16:9 video shot in 720x480. If the video 'looks stretched' ... something is wrong again. 16:9 video from a 720x480 source looks perfectly normal and unstretched, it simply occupies a frame that is 16:9 instead of 4:3 -- but it assumes that the source (or in your case, however accomplished, the transfer) correctly matched the shooting format with the clip format. Cheers, GB |
Thanks again Geoff, at least I know for sure I'm doing something wrong. When the project is complete i'll post it up in the 'show your work' section.
