Premiere Pro to Apple Color and back
Has anyone here had any experience with an easy workflow going from Premiere Pro to Apple Color and back to Premiere Pro?
I know there are plenty of other applications/plugins to use for grading but I prefer Color, but I also am liking what I'm seeing from Premiere Pro lately. But I'm not seeing an easy way to use them together. Any luck anyone? Perhaps FCP X will make this a moot point... |
Re: Premiere Pro to Apple Color and back
Premiere Pro can export and import FCP XML files, which are accepted by Color, so there should be not much of a problem going there and back. However, not everything is translated in the process, so it works best for raw edit with nothing else but cross fades.
I knew about the XML export, which works fine, but the problem is that Color doesn't support all the different flavors of video that Premiere does... here's where I was hoping to hear a success story.
Premiere can edit just about anything without the need to transcode, but in order to grade in Color, you are going to have to transcode anyway unless I am missing something here. If this is the case, you might as well just stay in FCP/Color land. I thought I already knew the answer to this question, just curious if anyone has ever had success or even tried this workflow direction... |
Unfortunately, you are correct. We've had similar problem with mp4 files from XDCAM EX camera. FCP can edit it with relatively little problem, but Color requires rewrapping them into MOVs, and preferably converting to ProRes.
it doesn't matter. color doesn't want to read FCP XML from PP. it will either crash or open an empty project, so the rest is moot for now pending a bug fix from adobe
