Export to OMF File Size Error
I'm trying to export audio to an OMF with a Handle Length of 5 seconds for a film I'm working on so the sound guy to do his thing but I keep getting the "The resulting file would be greater than 2GB in size and is not currently supported" error. I understand that there is a 2GB limit but I get this error even when just trying to render 10 second of audio with a 5 second Handle.....
My settings are 48KHz - 16-bit. All the boxes are checked below. I have tried deleting all the video tracks so that only the audio is in the sequence. I made sure that the entire sequence is rendered but I still keep getting this error. When I set the handle length to 1 second it seems to work fine. Why can't I do a 5 second handle length? |
Re: Export to OMF File Size Error
Another weird thing is when I export out a 1 min OMF test file with a Handle Length of 1 second, the file is over 1.5GBs.........1 min is almost 2GBs really??!!??
