My mac won,t see some AVCHD clips
Hi all i have a problem which no one can help with so as it relates to mac i thought i'd try here. The problem is my mac won't see clips filmed with my Sony FS700 video camera AVCHD format when i film timelapse or when i tried 50p, everything else is fine. They just don't show up when i open import clips with FCPX or iMovie which tells me it's a mac issue seeing these clips. My mac is reasonably geared so i don't think that's the issue but here's it's specs 2 by 2.8 GHz Quad -Core Intel Xeon, Memory 14 GB 800MHz DDR2 FB-DIMM, Graphics ATI Radeon HD 5770 1024 MB, Software OS X 10.8.2 (12C60)
Thanks your help will be appreciated, Neville Hayes |
Re: My mac won,t see some AVCHD clips
Final Cut Pro 6 & 7(not X) don't work with 1080 50/60P footage.
Try converting with ClipWrap or MPEGStreamclip.
What version of OS are you on? The most recent version prevents me from accessing the contents of the SD cards from my GH3 and GH2 cameras even though FCPX will see the contents for import. On the desktop I do see a file on the Sd card but it is locked. However you can get around this by right clicking and picking Show Package Contents from the contextual menu. I have to do this a few times to get to my GH camera files if I want to use ClipWrap instead of using FCPX to import.
I would venture to say that if the files are truly invisible to the desktop then something is odd with the files as recorded by the camera or the card you are using is experiencing directory corruption. There is no such thing as a file the Mac can't see unless there is encryption specifically put into it. This is not very likely in your case. Are you connecting the camera directly to the computer, can it do this? |
FCP "classic" works with common broadcast formats. 1080p60 and 1080p50 are not broadcast formats.
Hope that helps... |
Working with 1080 60p right now in FCPX. Works great, huge file exports although.
Is there a process where the Sony camera "closes" the time lapse file? The only reason the file would not appear to your Mac is if the Sony camera has not entered the correct directory information to the file yet. This would be similar to looking at a disc from a DVD recorder that hasn't been finalized yet. The computer would not recognized that there is data on the disc. Finalize the disc in the recorder and suddenly everything is there.
