FCP 7 with new Mac Pro
I looked around but didn't see a thread devoted to just this.
Now that there must be new owners of the new R2D2 Mac Pro, could anyone chime in on how the FCP 7 migration is going? Or are FCP 7's days all the fewer in number? Do excuse me if there is a thread -- I just couldn't find it. |
Re: FCP 7 with new Mac Pro
Tim,
I will let you know in the next few days. I have been using my new Mac Pro with Pegasus RAID for 6 weeks now but only in PP CC. I moved from FCP 7 in Nov when I had to start editing XAVC HD and 4K from my F55. But I now have FCP 7 on the Mac Pro and need to move around footage over the next few days then I will bring up an old project to see how it work. From what I have been told it won't work well at all with Mavericks and that is the lowest OS that the new Mac Pro will run. More soon. |
Just used FCP7 on Mavericks, although on my 2009 MacPro, and it worked just fine. Haven't tried it on my new MacPro yet. Don't see a need to as I have migrated over to FCPX about 99%.
I'm running FCP7 for LIGHT DUTY edits on my Mavericks-equipped Late 2013 13" MacBook Retina. I haven't found any issues YET but I'm NOT pushing it hard. The iMac is still my primary edit computer. |
I have been running FCP 7 with Mavericks on my laptop from the beginning of Mavericks release. FCP 7 works but several ancillary programs have issues. Mpeg streamclip may not work and if you use Qmaster clusters then you better have them built already as you can't make new ones with FCP 3 install. Compressor runs and uses the clusters if made. DVD Studio also works on Mavericks. Since the new Mac Pros start at Mavericks you probably will have to find other solutions for some old favorite software but FCP 7 should work well for editing.
MPEGStreamclip works fine with Mavericks on my systems. A change in QuickTime prevents previews with exporting DV codecs but the results are the same as before.
Qmaster was falling apart on my MacPro long before Mavericks which knocked it out completely. DVDs take longer on the old tower now but it is faster than the previous version without Qmaster enabled. The new version of Compressor works great on the new MacPro but some codecs do not activate the new version of Qmaster. DVD MPEG for example. |
From these last testimonials, it actually sounds promising...
I'm waiting till the very last minute to make the move to the new Mac Pro. I'm milking my 2006 workhorse (souped up) as long as possible. And it really has been a workhorse. When I make the move, I'll undoubtedly need to get a hard drive thunderbolt stacker (to deal with those 4 "internal" drives I'm using). |
Hi Tim,
Sorry I have been quite, been away and just home again. Your plan sounds right to keep using the 2006 Mac Pro as long as you can. I did the same with my 2007 turbo Mac Pro which I am about to sell with Dulce 16TB raid. Amazing machine but I went 4K and XAVCHD with PP CC so I moved up and a new Mac Pro. |
Client of mine bought a new Mac Pro recently and installed FCP 7 as Legacy software. Seems to be working fine. He is thinking he will be moving to Creative Cloud but is keeping his options open. Just upgraded my Older Mac Pro main drive to Mavericks while keeping a BU system drive with Mountain Lion. So far the only issues once I upgraded BMD drivers are the known issues with clusters, Flip for Mac needs updating.
