-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   OMF import in FCP (https://www.dvinfo.net/forum/final-cut-suite/54998-omf-import-fcp.html)
Bill Dunn November 25th, 2005 04:12 PM
OMF import in FCP
Searching in vain to see how I import omf files back into FCP!!
Anyone?
OMF import into FCP 4.5???
Boyd Ostroff November 25th, 2005 04:31 PM
Hi Bill, and welcome to DVinfo. I changed the title of your thread so that people will know what your question is. Try to use descriptive thread titles if you want a faster response, titling them with your name doesn't give much of a hint! ;-)
I have never worked with OMF's so I can't help, other than suggesting that you look in the manual where there are a number of entries for OMF. None of them really make it clear whether these files can be imported however as most of the discussion relates to export. Does it work if you choose Import > EDL? Sorry, my ignorance is showing.... I don't really know what an OMF is! Hopefully someone else will be able to help though.
Richard Alvarez November 25th, 2005 04:33 PM
Automatic Duck
http://www.automaticduck.com/
Shane Ross November 26th, 2005 06:06 PM
FCP EXPORTS OMF...it cannot import OMF.
Glenn Chan November 26th, 2005 06:40 PM
You can export an OMF to an audio program. Mix your audio, then output a stereo wave file back into FCP. I think that's the workflow you're supposed to use.
