-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Lost controls in log & Capture (https://www.dvinfo.net/forum/final-cut-suite/68875-lost-controls-log-capture.html)
David Phillips June 5th, 2006 06:09 AM
Hi
I've lost controls in the log & capture box via the mouse. All other controls work except the 'play' button. I've also lost control via the keyboard.
The Log & capture box is telling me the VTR is OK.
Help please.
Regards, Dave
If you're forced to work, it means you don't know how to fish!
Boyd Ostroff June 5th, 2006 07:01 AM
Have you checked your device control settings? Perhaps they somehow got set to a non-controllable device?
David Phillips June 5th, 2006 07:08 AM
Hi Boyd, yes I did. Can't think of what else to do.
Would a clean install help?
Dave
Boyd Ostroff June 5th, 2006 07:15 AM
Have you tried this? http://www.dvinfo.net/conf/showpost....57&postcount=5
David Phillips June 5th, 2006 07:43 AM
I just followed Ken's instructions for dumping and re-setting pref's, still no change.
Dave
Boyd Ostroff June 5th, 2006 11:22 AM
Very strange... what kind of deck or camera are you using? Is there perhaps a menu option there which could affect this? Does it show "DV IN" on its LCD screen while connected to your computer? How about the firewire cable - have you tried a different one? Have you tried hooking up a different camera/deck to see if you still have the same problem? Does your camera/deck work properly when connected to a different computer? Have you tried capturing with iMovie as a test?
Just brainstorming...
David Phillips June 5th, 2006 12:38 PM
I'm using a Panasonic DV 2000 deck, and have just discovered that everything works fine if firewired directly from the camera to the DV in. (Canon XL1s) The deck settings look OK and nothing has been changed since using the computer yesterday. I suppose it's possible that the firewire from computer to deck has developed a fault, but at the moment I don't have a spare to try.
I'm going to try a clean install to see if that makes a diference.
Thanks for your interest Boyd.
Regards, Dave
David Phillips June 5th, 2006 12:52 PM
Thanks for your help Boyd, panic over.
Faulty firewire. I feel a bit silly for not checking the basics sooner.
Kind regards, Dave
