Desperately Need a Lossless HD Intel Codec
Hey folks,
So we're shooting a film with a Canon XL-H1 into a Mac Pro with a BlackMagic Multibridge pro card in SDI at full 4:2:2 1080p24 uncompressed. We have an internal SATA RAID of 3 250GB drives, and filled it up very quickly. We need a good lossless capture / timeline codec that does HD at 4:2:2 24p, and works on the Intel macs. All the codecs I've been able to find only work on the PowerPC macs. Does anyone know of a good solution to this? MJPEG seems to be the only option, but it has some issues with pulldown I think. -Brian Critchlow Digital Media Factory |
Have you tried the bitjazz codec? I'm not sure if it works with the mac pro yet or not but you can try out the free demo. This is a lossless codec that should cut the bandwidth in half. It may even do better if the shots have a lot of blank color such as green screen shoots. This is known as one of the fastest codecs right now and is perfect quality. If you are doing 8 bit 1080 HD then usually the video will be around 120 MB/S. With this codec you might be able to get around 60 MB/S with the same exact quality. If you are using photojpeg see if your system can handle photojpeg at 100%. This actually is a 4:4:4 codec when at 100% and it may preserve the quality a little bit better.
I know for SD photojpeg at 75% works very well so I would be surprised if it didn't work well for HD as well. |
Thanks for the response. We have installed the bitjazz sheervideo codec into the machine with no luck. Hopefully a universal version is in the works.
Photojpeg was our next thought. The macpro has no problem running at 100%. Our source footage is 10bit 4:2:2 1080i. Is there any noticable change by going to 75% on the codec so it matches the same color sampling? Are we going to loose other information as well? Cheers Brian |
I doubt the Bitjazz codec will ever be something you could digitize to live. |
Forgive my ignorance, but why not use Avid DNxHD for the timeline? It is touted as being "specifically designed for nonlinear editing and multi-generation compositing, including collaborative postproduction and broadcast news environments"
The 220 version can reduce the XL-H1's 10 bit 4:2:2 output from 1.485Gbps to 220Mbps. Sorry if you already considered this; I'm just regurtitating my online research. |
Hello,
Capturing uncompressed is the only way not to loose any information. The best HD intermediate format for FCP (your using a Mac Pro, so I assume FCP) is DVCPro HD. That codec is fast, offers 4:2:2, but only 8bit. The other option would be Avid's DNxHD. That codec is available for OSX, but not with an intel chip set. You'll probably have to use Boot Camp and Windows XP Pro to make that work on your existing workstation. The last option would be to use CineForm, but they don't have an .mov option yet (sorry). Using some other codec combination would be experimental and may carry rendering and compression penalties. HDV takes longer to render and compress compared to DVCPro HD, for example. You should experiment with a small clip first before using a custom configuration for a complete project. The only other option would be to use a much larger stroage system and go uncompressed. I hope this helps out. CJ Rogers |
At this point it all comes down to how it looks to you. Capture a few scenes as 75% and 100% and see if the tradeoff is worth it. You may not be able to tell the 75% is a little bit more compressed. One thing is for sure that even 75% would look a lot better than DVCPROHD. DVCPROHD only uses 1280x1080 pixels and isn't very good at compressing even that. Remember DVCPROHD is the DV codec of HD. Photojpeg at 75% for SD uses 2.7 MB/S compared to DV at 3.2MB/S and is light years ahead in terms of quality. With that said a photojpeg video at the same datarate as DVCPROHD will be of much higher quality. DVCPROHD may give you more realtime effects and more layers of video in realtime but the quality really suffers. |
Thomas,
Thanks, this is in line with what a lot of other local pros have been telling me. DVCproHD is great for offline, but the data rate and resolution just dont compare to photojpeg. We have made the choice to go photojpeg, our only issue now is that it wont capture in real time (14-18fps roughly), so we are having to capture uncompressed & go to photojpeg overnight. We are using an internal 750 gig software RAID 0, getting 187MBps |
