Buying a new Mac
All right, I'm going to be buying a new Mac soon. The question is . . . which one?
My first instinct was to go for the new Mac Pro, in the quad 2GHz flavor to slash some of that price down. But, I'm really not sure if I need that much power. A little more background--I'd consider an iMac, but as far as display goes--I was planning on hooking it up to my 32" LCD HD TV, since it has a VGA input. Is that a bad idea? The native resolution is 1368x768. Also, if that were the case (hooking it up to an existing display) would I simply be better of going with a mac Mini with like, 2GB of ram? I can't honestly say I'd be editing anything other than DV. HDV is a possibility, but not at the moment. I'd really like to get a decent system while saving as much money as possible at the same time. Right now I edit on my girlfriend iBook G4 with 256MB ram, so I'm sure anything would be better than that at this point. Any thoughts? |
The Intel MacMini has good video outs for your 32" screen and can handle DV/HDV with no problem at all. Of course the more you $pend the more performance you'll get- it's all reative to $$$$.
Welcome to Macintosh! |
Thanks. That was the main thing I was wondering about, whether my lcd tv would work as a monitor (work well, that is). And, I'm glad to hear that the new intel chips work as good as they do. But really, I still can't help the urge to buy a mac pro.
One other question, on the Mac Mini, it has a 1.83GHz intel duo processor. Is that a dual processor, or no? |
The problem is, that's a really low resolution for such a large screen, so everything is going to look like the "large print edition". It might be a good choice as a second monitor for editing video with FCP's Digital Cinema Desktop, but I don't think you'll like it for normal computer tasks. |
Thanks Boyd, you made a good point there. So confused, so confused. Maybe I should just go with an iMac, though, that would mean getting rid of my laptop to make room on my desk.
One point to note Avid Xpress Pro and Media composer only run on older PowerPC macs and currently dosn't work on intel macs.
I would skip the Mac Mini and focus on the iMac or the Mac Pro. The iMac is great if you are certain that you'll never need the upgrade options the Mac Pro can only provide. As a side note, the Samsung 32" LCD monitor is very, very good and it hooked up to the Mac with absolutely no problem. It even sent a monitor set-up file to the Mac which negated the need to do a color adjustment in System Preferences. |
The new 24" iMac might put you where you want to be in terms of price/performance. I'd give it a look and read some of the reviews which seem to be very positive so far.
My only gripe is that Apple chose to include FW800 where an eSATA connector IMO would have been much better for attaching SATA RAID storage. FW800 isn't getting that much use by most folks that I know. -gb- |
Most USB2 drives seem to be about $20 cheaper than a FireWire 400 drive and about $40 cheaper than a FireWire 800/400 drive. USB2 is workable but it certainly isn't as robust as any FireWire format. As far as I have learned USB2 shares the bandwidth with various USB devices in a way that makes video capture unreliable. A client of mine was trying to edit with a dual USB2/FireWire external drive and they hooked up the USB wire to the computer. The video files were captured with the internal drives and then transfered to the drive since the project went into hiatus for a year. They called me when they couldn't get consistent playback of the DV files. All I did was pull out the USB cable and install the FireWire cable and problems were solved. That's my one experience with USB2 and video files. If anyone has experience with USB2 capture I sure would like to hear it. |
I made the statement about eSATA because I have an external drive enclosure that has USB2 or eSATA. Obviously, if the new iMacs offered the eSATA option, I could transfer at much higher data rates. As it is, I am limited on my current iMac to USB2 which is okay for file archiving but not realtime SD video transfer. -gb- |
