s-video/composite video card for Mac/FCP?
I'm looking for a low cost card that will allow me to attach a CRT TV to act as a second monitor on my editing station. Any recommendations?
I have open PCI slots. dual 1.42 Ghz Powermac G4 |
have an ATI 9700 Pro Mac with an open DVI port (ADC goes to monitor)...looks like the DVI > video adaptor is a great solution! Thank you!
I doubt that they still make it (?) but the ATI Radeon 7000 Mac Edition sounds like exactly what you want. I've got one lying around still, there are probably others forsale out there.
It has a DVI port, a VGA port and an s-video port (with an adaptor for composite). You can use any two of those three ports simultaneously. It's a regular PCI card which can go in any open slot on your G4. Don't know whether they've kept the drivers up to date... |
most of the supported cards stay supported...mostly thanks to the BSD/Darwin relationship :) I've had some really weird hardware just work (nothing I'd trust to production...but cool anyway).
The way I have it set up is I have a DV Tape deck. I have that plugged into firewire to my G5, and I have the s-video from the tape deck going to a video monitor. I then have Final cut set to output video preview thru firewire and it feeds it to the monitor (Powermac>(firewire)>dv deck>(svideo)>video monitor.
You probably don't have to use a tape deck. I think that any good DV camera can input through firewire and output through s-video. I know I've done the same with my XL2 before we used our tape deck as a permanent solution. |
http://www.adstech.com/products/API-...id=API-558-EFS |
$180 for the breakout box or $18 for the adaptor. I have a camera I can use as throughput, but I use it as a camera, so I'm going to go with the $18 adaptor from apple. Thank you all for your suggestions...I'm eventually going to get a deck so I don't wear my heads on my little camera, but until I can afford that...I'll keep using it. |
