fcp export web HD
I just started using my new XH_A1 after a couple years with a GL_2. I have finished my editing and exported my project as a QT which I then open in squeeze to convert to .flv_ for web viewing. Squeeze aside, I can't seem to export the project from FCP without the letterbox effect showing or a large black border around the entire thing. I have trie a lot of different settings and am feeling very HD challenged, especially after I just figured out how to do this decent with the old camera. I have seen some web HD videos on this site that fill the frame and look really nice. Can anyone recommend a starting point for a FCP>Squeeze>flash scenario. My concerns are quality first, file size second.
Thank you for any help mateo MacBook_Pro 10.4.8 FCP_Express_HD Canon_XH_A1 |
are you using compressor? you should be able to hit one of the check boxes that take off the letterbox.
i'm not familiar with squeeze, i just import my QT files in Flash 8 and it converts and encodes it automatically. |
Mateo,
If your exported clip is destined for the web, I'd use the "export using Quicktime conversion" in Final Cut and select the H.264 codec which will give the best web-results. I'm not familiar with Squeeze but my guess it's an extra step that isn't required. FCP/H.264 will do all the work for you - and should not show the black letterboxing you're seeing now - which might be caused by the Squeeze application. |
thanks for the help
Thanks, mateo |
