How do I accomplish "inset" effect?
I have some footage shot from 3 angles. I would like to do a picture-in-picture type effect with one angle providing the main view and either one or both other views as insets on top of the main view. I don't care to move the inset frame around on the screen.
Stack the two clips, one atop the other in a sequence.
Set your viewer to show "image and wireframe". Click once on the clip that you want to inset. Grab a corner of the wireframe and reduce it down to the size you want, then drag it into position. |
Thank you Dean.
If you need to do this to multiple clips, you can adjust the size & center of the insets in the motion tab of the canvas, so that they all are the same size & in the same place.
You also may need to crop them just a little as the image may fall off a little at the edges. You can also use the motion tab to put in a drop shadow. (FCP) |
Thanks for that tip Chris. That will be a useful technique for this project. I've got HDV, DV, and analog Betacam to work with.
