blackmagic hdlink and apple 23"
I cannot get the hdlink to display an image on my apple 23" using an sdi source. The monitor works fine on other things and the hdlink works on other monitors. Is there some setting I need to apply?
Thanks |
Phil,
I am running an apple 23'' with a blackmagic card hd/sdi and a HD link. Without knowing your system I would uninstall your decklink and HD link utilities. Disconnect and powerdown your HD link then reinstall the software for your capture card. Then plug in your HD Link and install the HD link utilites ( it may need to do a firmware update ). Finally go into your audio video setting ( in final cut ) and select the Blackmagic setting that best fits your workflow. Hope this is of some help. It took me a few hours to get everything running right on mine Dave |
