Best spec for FCP STUDIO on Powerbook Pro
I would like to establish which is the ideal entry spec for a Powerbook Pro using Final Cut Studio platform. I know the requirements listed on Apple's site, sometimes they list the very minimum requirements, I found that sometimes minimum is not enough.
Also, if anyone has a Powerbook with FCP Studio & wishes to sell let me know please. Thank you. |
I am assuming you mean a MacBook Pro. The larger the screen, the better, the more memory installed, the better and of course the faster the computer, the better. Otherwise, all MacBook Pro models are sufficient to do excellent FCP work with.
I am looking for a second-hand macbook pro & keep coming across second-hand notebooks & seller says 12 month warranty. Doesn't warranty normally start from the time of purchase that is on the receipt? When I ask when did you buy, they say 1 month, 2 months, 2 weeks, etc.
Please explain. |
It's really hard for us to explain when we don't know anything about the specific computers you're looking at. But, for example, Apple sells an extended warranty known as "Applecare". It is transferable, and any remaining coverage could be used by you if you purchase a machine such as this.
For more information, see the following: http://www.apple.com/support/products/ But yes, warranty coverage begins on your date of purchase, and Applecare extends the normal factory warranty period. |
You can also try refurbished systems to save money instead of just buying from people. A little funny thing is if you get it from Apple it might come with a free upgrade like mine had 2GB of RAM instead of just 1. Turns out Apple doesn't take the time to downgrade returned and refurbished systems! So you will get AT LEAST what you order, but may get more.
On the Apple store go to the bottom right and look for the red tag sale. |
Is there much difference in performance between 2.33 Dual 2 Core and 2.16 Dual Core chips? I found 2.16 (great deal), but concerned about the difference in performance, everything else is same spec.
