Multi Standard Project Management
I have been using FCP since v2, I edit in both NTSC & Pal SD. I found that when I closed a PAL project and opened an NTSC project the presets had changed to PAL and had to be reset. The workaround was to have two users, one for PAL and one for NTSC. Now at 5.1 and adding 1080 50i and 1080 60i and various other possibilities do I have to add a user for each standard or have I been missing somethig simple for all these years when setting up my projects so that the presets stay with them? (feeling somewhat like the village idiot)
thanks Ned C |
are we talking "Easy Setup" or am I missing something .... what presets do you need to change?
