Motion to FCP Problem
What is the best way to get a motion project to FCP without losing quality?
I have tried a bunch of methods including the "lossless+apha movie" preset. What happens is I get the title in FCP and then export using compressor with the DVD mpeg2 preset but the text/graphics look extremely bad once I play them on the dvd player. In FCP, I have the sequences set to "ntsc DV" using square pixels. I tried other presets but each changes the look of the motion graphic. However, if I export strait out of motion to compressor using the DVD mpeg2 preset, the graphics look great! But there is no way I can edit this film in motion! My mac pro chokes on motion as it is. So, I am kind of in a bind. I am using the motion template - "sketch.NTSC" |
export as animation codec
Export as lossless alpha channel
Animation codec Doug T |
Doug,
Thanks for the tip. I finally found the problem, I just had the wrong sequence setting, doh! I guess I need stop relying on software to do the right thing. I knew it was something like that, I just had to fiddle with it and make a dozen or so DVDs. I just have to remember, always line up my project settings with my fcp sequence settings and I am good to go. I also found out you can import motion projects right in FCP which I am sure is common knowledge around here. I think the quality is just about as good as the animation codec but it seems more render intensive if I am not mistaken. Thanks again, I am glad I got around this. This project is due tomorrow! Jonathan |
