Compressor, QT Pro movies don't work on web
Compressor seems to have stopped producing compressions that work on the web. When I upload a movie and go to the page, there's the big Q and in the corner of the browser window it says 'Done,' so I assume it can't be loading.
I had the brilliant idea (cough) to use QT Pro and it worked well a couple times but then I tried another, and it didn't work. Any ideas? I've read that in Comp 2 adding saved settings can cause oddities down the line. How do I get rid of my saved settings? I thought dumping the plist would do it but they're stilll there. I'm using FCP 5.1.4 on a MBPro, 2.33. best, elmer |
you may be experiencing codec incompatibilities. if you use QT7 Pro to make a MOV, just be sure you have selected h.264 and you shouldn't have a problem.
(I just did this today, if you're interested Water Lily Timelapse) |
Best, Dino |
I didn't know how long the blossom would take to fully open, so I couldn't calculate an interval time. (I used an HVX200 in interval mode, taking one frame every one second for 3.5 hours)
So I wound up with about 7 minutes of video, which I then ran at 2000% in FCP to bring the total time down to 20 secs. And yes, I used manual iris, which stayed fixed the entire time, so it starts to blow out at the end, so I stopped it down the last half hour to see what it did. This was all just an experiment for me to work the bugs out. In future I will try auto-iris. |
First of all,very beautiful video! My question is if this INTERVAL MODE is available on the Canon xh A1,or if there is a way to do the same. thanks |
It's been a while since I used it but I think ScenalyzerLive capture software for PC lets you capture frames time-lapse style. Not sure if that works from tape or just live. There's a free demo.
Shayne Weyker http://weykervideo.com |
