Flash Help
Hi,
I need to embed a short clip inside a Flash Site... (Iīm new to FLash MX Embed Video feature) The problem is that no matter what I do... audio is not in synch with image... Iīve tried all Iīve read on tutorials... but I canīt seem to make it work, and migraine is kicking in.. so I quit for today, leave a message in this board... and hope tomorrow I get the magic answer, from someone who had this trouble before... or expect that the client changes his mind and letīs me put the video in plain old quiktime. Any suggestions? |
I've never worked with it before, but what resolution and framerate
is the video going in? I'm thinking that it must be quite low for it to playback correctly through such a system? |
The source video is a Quiktime 320 X 240 at 25 fps, stereo... about 2 minutes long and 2.8 megs in size.
I also did a test on lighter version that goes at 15 fps, mono... but it still wonīt play the sound right. I quit trying.. and Used a demo version of Wildform flix Pro.. which did a good job converting the MOV to .SWF... and I can easily call that .SWF from within the main Flash site and it plays pretty well and "streams" about the same speed as the origninal MOV... But still I want to use Flash for this.. I know it can be done, but these past few days I canīt seem to do anything right, so Iīll wait a few days before trying again... (Iīm in luck the client is taking holidays until january). |
Are you trying to embed it as a .fv, swf or quicktime?
You have to make sure you are embedding the audio and video together, otherwise the audio will play at the frame rate of the project and not the video. Zac |
I have some tips...
1. (Best solution) Install and use the latest Flash MX 2004. It's handling of video through .flv is almost perfect. A lot more encoding options, streaming capabilities and quality of playback is great. The .flv codec is installed with the flash application allowing you to directly export ready-to-go files in Quicktime (Pro). Then, it's a simple case of calling it externally. You can add a simple code to show the standard quicktime-like player controls in your flash file. The only drawback is Flash Player 7+ is required for playback. I've tested this on some of our videos and the quality is excellent. 2. Failing that, try adding a slight blur to smooth out fine details in your clip and do some adjustments to reduce unneeded contrasts. Finally, use a jpeg codec in your source clip like Apple Photo JPEG. 3. The usual - reduce frame rate and size of your clip. If your flash file is set to playback at 12/15/18, i would keep my movie clip to those as well. 4. I might even try striping the audio to just mono. 5. Long clips have an issue going through the import/encode process in flash. Try cutting long clips into multiple sections and stitch on timeline with actionscript calls. 6. We once had a perfectly synced long clip until it reached one frame of black inserted between 2 full-motion video frames. The black completely threw th audio out of whack. 7. Reduce encode quality and do not import at a frame-size larger than what you intend to use. Hope that was helpful. |
adding...
We just finished a CDROM project that contained about 2hrs of videos. We used MX 2004 and shrunk the file size considerably while increasing video-quality three-folds. MX 2004 makes Flix pro (which i never liked in the first place) kinda obsolete. Merry Xmas. |
Ok.. so I guess Iīll give MX 2004 a try... I donīt think the client cares about the player version, the clip is actually a whim that not many will even want to see... and I just used the Flixpro to have a Beta Version to show... (I like to stay in Flash as much as possible).
But... Iīm still puzzled by why it isnīt working.. To answer Zac.. Iīm trying to use the IMPORT VIDEO option that Flash MX gives you .. where it shows you a Sorenson window to compress... and then it fills the timeline and creates the .swf. Then from another movie I call the .swf created with the above method. I havenīt tried anymore since the holidays and all.. but I guess on monday Iīll go for it again. |
