Encoding for the Web
Ok, I was wonding what people were using for settings when encoding a video for the web. The clips will be around 30 mins in length, they will be streamed from the server so they need to be under 100 megs. Windows media is the prefered player. Now in the past I never played with the quality, bit rate, non of it. I just chose the size and the codec and rendered. But I need to stick to these specs for now. As usual any and all help is welcome.
As always, the best advice I can give you is to do some trial and testing
yourself. It is a far better approach since you learn how your product operates and what works and does not work with the product/footage. Having said that, the question really is impossible to answer if you are not telling us which exact encoder you are using. Each has different templates, presets, options and quality levels etc. |
Clint,
We just last week had to cross that very bridge: an editied church broadcast of 30 min for web-delivery. We posted three links, a 56k Windows Media Video for dial-up users (though they'd still have to have monumental patience to download it), and two 'broadband' files. We selected 100k and 256k at 18mb and 56mb respectively. These are rendered directly out of Vegas using established settings for wmv files. Results were satisfactory. |
since you want it to be streaming, with no breaks during playback, also look at things like using mono audio for both streams... the less bitrate the better... streaming video will probably have to be cbr if you are playing it back from a real windows media streaming server.
Another question.... When people render out for the web, say like trailers, are they are full frame rates or are they at something way lower? I'm thinking that's where I am bulking up my file size.
In layperson terms, encoders are looking to eliminate parts that don't change much from frame to frame. By lowering the frame rate you're actually creating GREATER difference from frame to frame (objects move more from one frame to another at 15fps for example). For that reason you're not reducing the file size as much as some would expect. |
one factor is also how sophisticated the media player is at filling in for a lower framerate, to make it look more natural... you'd have to test-code your footage in different media formats to see what works best, but wmp gets the nod there from what i've seen.
frame size is another factor for trailers that must have the best quality, it's more efficient to keep the 720x480, just use the 640x480 square pixel size for broadband clips. |
Ok I have got a few nice renderes out but now I am curious on what format you guys render to? Quicktime, windows, real? What are the pros and cons of each?
A lot of people (still) seem to dislike the Real player. I don't have it installed
(neither will it be) and I know lots of others with that feeling. Personally I would stick with both a QuickTime and Windows Media version of your movies. That way everybody should be able to view your movies and get the format they want to view it in. I personally like it if people include a download link so I can download the movie to my harddisk and watch it at 200% (which I almost ALWAYS do with web movies, also due to my screen resolution: 1680 x 1050) and keep it in my archive of web movies I really enjoyed. With QuickTime a lot of people seem to be using either Sorenson or the MPEG-4 codec. Windows Media comes with its own codecs which are pretty good as well. |
