Firestore DR-DV5000
Hi,
Anyone got trying use on SONY DSR-370P or Panasonic DVX100? Its works or not. Thanks for reply! |
Hi Yeong,
Your best bet is probably the FireStore FS-3 as it comes standard with either Anton/Bauer or Sony/IDX mount plates. You can also use the FS-3 with the Anton/Bauer Stasis mount on your DVX100. We have tested both camcorders and they both work. Hope that helps, Matt |
Hi,
Matt. Because my here someone are offer me a best price for the DR-DV5000 . I'm consider to buy the DR-DV5000 for both camera , can you help for try out this model? because i have a JVC GY-DV5001E , so i like to share with this and both another cam, thanks . <<<-- Originally posted by Matt McEwen : Hi Yeong, Your best bet is probably the FireStore FS-3 as it comes standard with either Anton/Bauer or Sony/IDX mount plates. You can also use the FS-3 with the Anton/Bauer Stasis mount on your DVX100. We have tested both camcorders and they both work. Hope that helps, Matt -->>> |
Hi Yeong,
Because DR-DV5000 is designed to work on JVC camcorders, I do not believe it is possible to mount to the rear of a Sony camcorder. There is a special 52-pin connector for interfacing with the GY-DV5001/5000 that may prevent you form mounting to a Sony camcorder. Physically, the units are quite different. Maybe someone can post other experiences. Hope that helps, Matt |
Oh i see,
thanks for reply :) <<<-- Originally posted by Matt McEwen : Hi Yeong, Because DR-DV5000 is designed to work on JVC camcorders, I do not believe it is possible to mount to the rear of a Sony camcorder. There is a special 52-pin connector for interfacing with the GY-DV5001/5000 that may prevent you form mounting to a Sony camcorder. Physically, the units are quite different. Maybe someone can post other experiences. Hope that helps, Matt -->>> |
