Startup problems
I have been checking out an FS4 Pro 40gig for the company I work for. Everything checked out fine. The next day I switched it on and got nothing but the cooling fan running - no display and no status light. I could only switch it off by disconnecting the battery. After about an hour of powering it on and off it suddenly started up OK. This was a couple of days ago and it's been fine since. Anyone had this problem?
Yes I have had the same thing once on my 80GB pro version. I pulled the battery and put it back on and it was OK straight away...
I'm going to use the pro version in ernest at the end of may so hope it behaves itself, even though I will still be using tape as well. I'm also in need of more batteries, or a bigger capacity battery which I believe was promised a while back... I also have a problem where the backlight flickers on and off. I'm waiting on a response from the UK Distributor Holdan. Mark |
