FS-4 HD M2T Files In Premiere Pro...NOT!
I bought an FS4 HD unit so that I could record and use the m2t HD files in Premiere Pro....but it does not work. When I drop the files on the timeline, the files are pixelated at the beginning of each clip and the audio is out of sync.
I cannot find any online solution....someone wanted me to try streamclip from squared5.com, but it doesn't have any HDV settings that I can see, and conversion defeats the whole purpose of getting the FS-4. The Focus tech guy asked me endless email questions before telling me the FS4 HD won't work with Premiere Pro. Anybody find a solution to this?? The FS-4 is going to be sold shortly if I cannot find a way to use it! |
Not sure this will work... but try to rename the m2t files to mpeg
see if this helps... |
Depends on your version of PPro. The m2t files don't work too well in PPro 1.5.x, but are supposed to work in PPro 2.0. If you're using PPro 2.0 and have read the help & Adobe forums, you might try the Premiere forum here ("Attend the World Premiere").
ciao, Matt |
I'm using 2.0....and it doesn't work.
No....why?? (That's an unusual question.....)
I have the following setup:
-FS-4HD -JVC HD100 -Adobe Premiere Pro 2.0 For me, the m2t files import without issue into Premiere. I have experienced your symptoms when capturing video from the tape through CapDVHS, but that was solved with HDVSplit (it came down to an mpeg2 transport that Premiere doesn't appear to recognize). |
It has worked a few times for me, but not consistently. I'm going to wait for the new CS3 version of Premiere Pro and try again, before I dump it. Also, I hear that the new Pinnacle Studio 11 handles high def m2t files (with an extension of m2ts), so I'll try that too.
I've never seen the 'HDV' files work from these units - I was one of the first to get the upgrade and I'm sure I'm subsequently one of the first to give up on it.
FS4 DV works FS100 works FS4 HDV is a class action suit (my apologies if I'm wrong) |
I agree....by the way, the HDV files won't work in Pinnacle Studio 11 either.
A silly, ignorant and possibly a goosechase propogating question - but - I understand firestore to be written to disks formatted in FAT32, not NTFS.
Premiere Pro 2 and the operating system it resides with, Windows XP, more often operates in a NTFS file system. I have observed when extracting files from a normal hard drive drive formatted FAT32 and temporarily fitted up to the NTFS computer to copy the files, the task will happen, but much more slowly. Maybe I am mismanaging the system. I wonder if, rather than operating the firestore to the computer and PP2 as an external hard drive, whether copying the entire files onto another internal drive formatted to NTFS, then importing those files to PP2 may help? Maybe not if there is a proprietary operating system inhabiting the firestore drive and essential to the playback of those files. One step furthur would be to convert those files via HD Link to cineform .avi before importing them to PP2. Ignore my comments at will as I am only guessing wildly. FOOTNOTE EDIT: Go to this discussion - http://www.dvinfo.net/conf/showthrea...519#post685519 it refers to a method of copying the firestore files using DOS script which might be a solution to your problem. |
I Have copied the files from FS4HD to my XP drive many times before importing and no success. The format of the drives makes no difference, it's the format of the files....but I'll check out the link you sent, thanks.
The files are in 2Gig sections because of the FAT32 format, so maybe that's the problem....maybe I have to combine them as one file before importing.......I've been trying to import the individual files, instead of the complete file....we may be on to something here, or maybe not...... |
"Concatenation" copying of the files via a DOS script was more extensively discussed as a genuinely viable problem solver in a dvinfo post a while back. I only remembered after having read the cineform post which I linked you to.
I could not quickly find that post which offered the solution and it may be buried fairly deep by now but it is most likely in the Firestore discussions. The DOS command in that post was accurately written as far as I could tell. |
Danny Fye www.dannyfye.com www.vidmus.com/scolvs |
Hopping Mad
This FS-4 Pro HD incompatibility with PP 1.51 has made me look like an ill-informed dunce at work. I convinced my superiors to purchase the HD upgrade only to find it's useless for HD capture for Premiere. Here's what I've found so far:
m2t -File format not supported in Prem Pro 1.51(PC) -Renaming to mpeg causes Prem Pro 1.51 to choke on import, forcing a quit (PC) -File format not supported in FCP HD 4.5 (Mac) -FCP imports renamed-to-mpeg files, but black screen, no audio (Mac) mov -File format not supported in Prem Pro (PC) -File format not recognized in FCP HD 4.5 (Mac) -Causes Quicktime 7 to hang, forcing a quit (PC) -Causes Quicktime 7 to hang (white screen), forcing a quit (Mac) (The aforementioned DOS concatenation method doesn't work for me either: Prem Pro 1.51 still does not recognize the new concatenated file.) Can anyone confirm that m2t (or mov) files captured with FS-4 Pro HD work in Vegas 7? I used up my trial long before this issue and would appreciate some input before laying down the cash. Thanks in advance. |
