60i capture help
Ok I have a problem capturing on my pc with the Canon HV10, every program that work(HDV split, Nerovision) on detecting my HV10 are only capturing to file of 29,97 fps. Before I could do it in 59.94 fps but now I don't know what happen I can't anymore.
Please realy need help on this one, i've search the forum but can't seem to find the answer |
Common guy's surely somebody as something to say to me, ok then can you tell me when you guy's capture with hdv does'it capture in 60i or 30p
While many have tried to standardize the naming of frame rates, many companies find ways to still confuse people.
When it is specified that a camera operates at "29.97i" or "30i", it means that it will have 29.97 interlaced frames per second. When it is specified that a camera operates at "59.94i" or "60i", it means that it operates at 59.94 fields per second (or 29.97 full frames per second). Notice that both of these definitions are exactly the same. Whether measured in frames or fields, you get the same number of full pictures per second. **Exception. Some higher end cameras have the ability to operate at 59.94 full frames per second. However, this is most commonly noted as "59.94" or "59.94p". Hope this helps. |
The nomenclature has changed such that previously we spoke of no of frames for progressive systems, no of fields for interlaced systems - the standards bodies have now decreed that the nomenclature should ALWAYS refer to no of FRAMES, regardless of progressive or interlace. Unfortunately some manufacturers are much slower to adopt the new terminology than others, but what you're now seeing is manufacturers doing just that. |
