Go Back   The Digital Video Information Network > High Definition Video Acquisition > General HD (720 / 1080) Acquisition
Topics about HD production, including the Sanyo Xacti.
Old July 27th, 2009, 09:49 PM   #1
HD Helmet Camera
What is the best buy for a buck? Can be 720p, but must produce decent picture and be Final Cut compatible. Thanks for suggestions!
Robert Rogoz is offline   Reply With Quote
Old July 27th, 2009, 10:54 PM   #2
What sports/activities do you want to shoot, how small do you need the camera to be, and what are your requirements for video quality? If you can deal with something handycam sized mounted on a helmet, there are lots of relatively inexpensive options that will do a decent job. If you want something really small or if you want to ensure that there are no compression artifacts due to large amounts of motion in the frame, things get very expensive very fast.
Mike Sertic is offline   Reply With Quote
Old July 27th, 2009, 11:02 PM   #3
Check out some of the stuff i do here, mostly on water video footage with POV cams.
Just getting into HD now as they become affordable and available. Lot's of info on mounts and testing, check the categories.
Rambos Locker Outrigger Canoe Blog: New GoPro HD Cam – High Def @ 1080p
Cheers Rambo
http://rambos-locker.blogspot.com
Ocean Sports Videography (POV Specialist)
Ian Newland is offline   Reply With Quote
Old July 28th, 2009, 02:35 PM   #4
It has to be small, the quality is an issue, but not as much. It will be used for filming on alpine climbs (Patagonia, Pakistan and so)- guy is a real hard core, but wants to enhance his still for slideshows with footage. Palmcorder is too heavy, so are the other options. I just wanted to see about something like this: VholdR | ContourHD Wearable Camcorder | 1200 | B&H Photo Video . Sony is too $$$$. V.I.O. | POV.1.5 Digital Helmet Camera System | POV150 | B&H is only 480.
BTW it won't be a fast moving action shots. Thanks
Old July 28th, 2009, 04:45 PM   #5
If it's cold conditions he will also need to consider the type of batteries the units will take. Only Lithium's will work in very cold areas. Water and dust proof may be another consideration, most POV cams are water resistant only. The GoPro is the only one i know of enclosed in a small lightweight waterproof case (too 100ft). There are mount options for head, chest, pole, suction, clip-on etc. Wide angle is GoPro is 170 degrees, perfect for HeadCam footage.
Size is smaller than a mobile phone.
Cheers Rambo
Old July 29th, 2009, 09:23 AM   #6
I checked the page, but did not see the specs for this camera (size and weight). It sounds like a good unit, but also I could not find it in stock yet at any retailer. Any info on that? Thanks
Old July 29th, 2009, 04:06 PM   #7
Hi Robert,
Waterproof: rated to 100 feet/30 meters
Dimensions: 1.75" x 2.30" x 1.25" or 4.45cm x 5.84cm x 3.18cm (H x W x D)
Weight: 4.9 oz or 139g
Rugged and reliable and expendable, i have 15 of the SD models all still working after getting a hard time, some modified with radio control and long delay timers.
Highly recommend them.
HD Available Sept 2009
SD Available now
GoPro - Wearable Digital Cameras for Sports
Cheers Rambo
Old October 30th, 2009, 10:32 AM   #8
Just ordered the GoPro HD version. Supposed to ship next week.
Plan on trying it for mountain biking.
David Moody is offline   Reply With Quote
Old October 30th, 2009, 06:57 PM   #9
What is the format this camera (gopro) recording in?
Old October 30th, 2009, 07:45 PM   #10
Lots of Gopro help and info in this GoPro forum
http://goprouser.freeforums.org
Old October 30th, 2009, 08:31 PM   #11
If it comes before Christmas, santa would like to see some footage if you have time to post it.
Matt Buys is offline   Reply With Quote
Old November 1st, 2009, 12:15 AM   #12
GoPro Hero records in AVI format using the "Sony Motion JPEG" codec. Here's some footage from the one and only day I used it:
http://s94261448.onlinehome.us/video/GoProSample.wmv
BTW, I have it up for sale in the Classifieds forum.
Chris Davis is offline   Reply
  You are here: The Digital Video Information Network > High Definition Video Acquisition > General HD (720 / 1080) Acquisition
Google
