Help in chose a HD Camcorder with Full Manual Control (W/LANC)
Hi, I need some help in chosing a Camcorder with Full Manual controls (Shutter Speed, Aperture, ISO, ) my budget is (£250-£400) not sure if a canon HV20 offer me that. if not which camera Preferable Canon or Sony with LANC is a Good invest these days?
Thanks |
There is no LANC jack on the Canon HV series camcorders, sorry.
I don't know the Sony line very well (hopefully someone else will respond), but the new Canon HF S series flash memory camcorders have LANC. When they are operated in Tv (shutter priority) mode plus Exposure Lock, you have a fixed shutter speed which won't change and manual control of exposure. Hope this helps, |
Andy -
Your main problem is the budget (ain't it always!)... As Chris stated, the newer HF-S (the s11 and s21 IIRC) canons have manual control and LANC capability, and I seem to recall something about a couple of their new lower priced ones may have the LANC jack too... From the Sony side IF you want full manual, you're looking at either the XR550V or the CX550V just announced, soon to be available, these are the first Sonys in a while to have manual control... LANC is accessed via the A/V jack on these cams. And since these are the "top of the line" models, you're out of your budget range. Only other possibility is maybe find a used/just officially discontinued DSC-HC9 (contemporary to the HV20/30) - that has full manual and the 2.5mm LANC jack, but it's a couple sensor generations behind the current crop of tapeless cameras... good camera, but the sensors have advanced so rapidly, it looks a tad dated already... |
Thanks for the help maybe my budget is too low for my expetations, what do you think about the Panasonic SD700? do you think that one will have manual control & Lanc?
Panasonic isn't licensed for LANC. They will have an Aux jack, same type of control features, but compatible only with a proprietary controller, not LANC. Not sure if the SD700 has an Aux jack though.
About LANC via A/V how does it work, can you give details? My CX550 is on is way and I did'nt see LANC from the specs.
I found it! Just need the Lanc adapter.
