Does Edius support 720/25p
Hi, this may well be a stupid question.....sorry.....but does edius 5 support 720/25p HDV ?
I cant find it in the specs, only the higher frame rates. I run an older DVStorm 2 Pro package and want to upgrade to support my new HD workflow. cheers John |
There's a generic preset that matches.
Video Frame size : 1280 x 720 Frame rate : 25.00( 25/1 ) Pixel aspect : 1.0000 Field order : Progressive Audio Rate : 48000Hz Sample size : 16 Bit Channel : 2 Additional Info HDV AVC-Intra100 I'm pretty sure Edius 5 does not, and will never support the DVStorm2 though, if that's your plan? |
Thanks for the reply, I am planing to upgrade to the Edius HD package that includes Edius 5 as long as it suports 720/25p.
Thanks again John |
Even Edius Neo- which I've got on my laptop for home use- captures and cuts jvc hdv 720p 25- and does it well. I've had a few headaches with avid trying to capture and cut this footage: edius works a treat.
(BUT: neo will not import from p2, so is no good for dvcprohd projects. You'd have to get Edius 5). |
