MPEG2 versus H.264??
I've read somewhere in Adobe's site. It is said that H.264 can actually produce the same quality as MPEG2 but with half data rate. And I've read somewhere else saying that MPEG2 can produce 2 hours HD project for single Blu-ray disc, while H.264 can produce 4 hours. If this is the case why don't we all just use H.264 and drop MPEG2 for all our HD Blu-ray projects??
Any comments?? Thanks in advance. |
Can I combine the two into the same blu-ray disc for authoring?
Some tracks MPEG2 and others H.264. |
I have been testing some of my FX1 footage (edited with a Cineform intermediate), and have not been as happy with the MPEG2
I also think that 2 hours for MPEG2 and 4 hours for H.264 is generous. A single sided BD-R is 25GB, which is the same as your 1 hour HDV tape recorded in MPEG2. To get two hours you would have to halve the data rate of your original source. Blu-ray movies that come out on 25GB discs with MPEG2 are not considered reference quality. It may be overkill, but I am using H.264 with under two hours of length so that I don't have to use the lower quality setting in Encore CS3. |
I may be confused, but I thought that HDV 1080i was 25 mb/sec.
I seemed to get some stuttering with MPEG2 on some time lapse footage that I did not get with h.264, so I switched to h.264 For three hours of footage with h.264 I have to go to lower than standard settings with Encore, and I seem to notice a difference in compression artifact. It takes a while to test different encode rates when the render is 48 hours, so I am still experimenting. |
Regarding your test renders, try running them on a short (e.g. 1 minute) clip for testing purposes, so you don't have to wait 48 hours for the results. :-) |
[QUOTE=Kevin Shaw;756385]25GB is more than enough for two hours of 1080i HDV at full 25 Mbps bandwidth, which is consistent with the fact that an hour of DV or HDV footage uses about 12 GB of storage when captured to a computer. You can also calculate this directly by figuring that 25 Mbps = 3.125 MB/sec plus another 48 KB/sec for audio, or ~11,423 MB per hour of HDV. [QUOTE]
Kevin. How does this calculation applies to H.264? I looked up in premiere media encoder. MPEG2 Blu-ray - HDTV 1080p 25 High Quality Target Bitrate 30Mbps H.264 Blu-ray - HDTV 1080p 25 High Quality Target Bitrate 25Mbps. So what I don't understand how can H.264 fit 4 hours of video on blu-ray disc. If we use your calculation above, we can only fit about 2 hours of video either using MPEG2 and H.264 compression. Thanks Kevin. |
I got you Kevin. Thanks. It all make sense now.
