Best lossless codec for archiving?
Hello there. I am about to archive my short film collection onto some external HDD's. At the moment they are uncompressed and very large files. This isn't too bad, but I would prefer to make them slightly smaller using a small ammount of compression.
I know of Huffyuv and Lagarith but I am worried about the future-proofing of them. If I encoded in huffyuv I assume that I could not read the files on another computer that does not have the codec installed. My question is, other than uncompressed, what are the other best options for archiving to HDD? (As future-proof and compatible as possible). Thanks. |
Well for any of the "lossless" codecs, you will face the need to have that codec on the computer you are using in later years. So since huffyuv is freeware and tiny, I'd actually consider that quite a good option.
The bigger challenge may be to guess which codecs will still be easily installable on future operating systems? |
In all honesty I think tapes would be the best thing. Get some long run evals of HDcam or Digibeta and just lay them off.
Linear Tape-Open - Wikipedia, the free encyclopedia |
I place all project files into a folder and zip it... Usually get ~20-30% compression for the whole project; obviously some files more than others. But it is completely lossless, and I don't have to worry about future proofing the codec other than choosing the right one to work in to begin with. Since you're uncompressed that shouldn't be a problem and I would think you'll get a fair amount of compression.
Thanks for the replies guys.
Mark, I never thought of ziping an avi file for archive. It seems like a good idea so I will give it a try. Thanks. |
The next generation of LTO drives, due out the end of next year (approximately) will store 1.6 terabytes of uncompressed data per cartridge. The generation after that in roughly another two years will store 3.2 terabytes per cartridge. There are at least 2 to 3 million LTO tape drives in the field. IBM passed the million mark last April and we continue to see projections of 400k to 500k drives per year total across all manufacturers.
With this many drives in the market, LTO will be here for a while yet. I was at a technical storage industry symposium last week in San Diego and a gentleman from Sony gave a presentation on how they were going to get to a terabyte per disc with Blu-Ray. They don't see getting past 400 to 500 gigabytes with a system that will read today's discs. There doesn't seem to be any real chance of using a shorter wavelength laser but they think they can get up to 8 layers on a disc. Tricky stuff - they will need variying thicknesses of spacer material between the layers to prevent unwanted optical interference. Data rate will never match what LTO can do. There are a few technologies that will eventually be capable of 10 terabits per square inch, both on HDD and SDD. It's doubtful that tape will get to these bit densities due to the need to read and write on different drives and interchange cartridges, as well as the reality of dealing with flexible media. Tape thickness will be going to around 5 microns and length per cartridge is already approaching about a half mile. |
then, which lossless codec???
hey guys, ok, tape backup is the best.. but it seems, buying a 1TB hdd and archieving is the best solution for me (and sure for other amateurs/home users)..
well, back to question, .m2t files are huge files, how can and which format can I compress them into? anyone could give the instructions and links for compression huge .m2t files to store on HDD?? thank you. ------------------ Sony FX1E |
There is no "lossless" codec that you can use that will produce files smaller than your raw m2t files from the camera - those are mpeg2, which is a highly compressed format.
A good solution currently is Cineform, which uses wavelet compression to produce highquality avi or mov files that aren't too much larger than the source m2ts. The encoder is costly, but the decoder is free and can be installed on an unlimited number of machines. |
