Help on graphics card selection etc.
Hello everybody!
I am about to put together my new PC for HDV NLE. (The main use will be Photoshop though.) The software I already have is Premiere Pro with Aspect HD. So far I've been following more or less the DIY6 recommendations from VideoGuys. I had planned to buy the PNY Nvidia Quadro FX1700 Professional Video Edition card, but started having some doubts: - Do I really need the video breakout box, isn't HDMI sufficient? (or are there other differences between the normal FX1700 and the PV edition?) - Is it justified to spend that much on a card that's more than 1 year old? - Cineform prefers Quadro to Geforce, right? Another question mark concerns the system memory (4GB): I plan to get a Core 2 Quad Q6600 G0 on an Asus P5Q, or P5Q3 board. I've heard though, that the P5Q3 is very touchy about the memory. Should I just stick with DDR2 on the more stable P5Q instead, or will I regret DDR3? Any suggestions that would help me to at last (have been planning this for a couple of years...) take a decision and get on with creative work will be highly appreciated!! Many thanks! |
If you're going to be using software that relies heavily on OpenGL, then the beefier cards will speed your rendering times. If not, you can probably save some money there. Quote:
However, that puts you in the realm of being on the bleeding edge. That's somewhere I don't want to be when it comes to the world of video. Quote:
Now that I've said that, I find their whole config a bit curious. The build 1 system looks quite similar to a high end computer one might get at a good electronic retailer... at twice the price! Yes, it has a beefier power supply, a snazzier case and of course the video card, but 2GB of RAM? XP not XP 64? There seems to be a good bit of margin built into this system |
Thank you so much, Tripp, for having taken the time for your answer,
and thanks to the whole DVi community for being such a great source of knowledge! Quote:
_____________ Louis de Stoutz |
