DVCProHD Components 1.1 download at Apple??
Hey, I just ran across this and haven't seen anything posted about it anywhere! Will this help or screw up LumiereHD??
http://www.apple.com/support/downloa...omponents.html About DVCProHD Components 1.1 All users of Panasonic AJ-HD1200A VTRs should install the latest revision of the DVCPROHD components (1.1). This updater only updates QuickTime components used by Final Cut Pro HD. It does not update the Final Cut Pro HD (version 4.5) application. Before You Install Make sure you do the following before you install the software: - Install or upgrade to Final Cut Pro HD (version 4.5) if it is not already installed on your computer. - Upgrade to Mac OS X v10.3.4 or later and QuickTime 6.5 or later. - Quit Final Cut Pro HD. After You Install -Restart your computer. -Open Final Cut Pro HD. |
Murph,
My understanding is this will help with the compatibility with the DVCPRO HD Deck. |
Yeah, those $40 - 90,000 decks, NOT our $2000 clamshell HDV VTRs! :-)
heath ps-I wish I had a clamshell! |
I installed it anyway, just so I could feel some type of connection to the higher end equipment. :)
Murph |
