Whats the Best SATA RAID controler ?
I need to achieve around 200mb/s transfer rate to do uncompressed editing. For this to work I understand I need to get the best PCI-X SATA controler to RAID-0 a stripe of 4 Western digital 500gb drives. I just need to know which controller card is the best and will do what i want. What are you useing?
The most important factor is ensuring that the drivers of whatever solution you get do not utilize much CPU. Software RAID would normally be a great option except that many SATA controller chipset drivers utilize a lot of CPU (compared to SCSI controllers). |
I have tried many controllers in the search of using cheap SATA storage rather then the only logical choice of SCSI. After a couple of thousand of dollars in SATA cards I was able to get the 3ware 9650SE-8 with 8 Seagate 400Gb SATAII Drives to run 400+ MB/sec sustained for at least 1 hour and write at a rate of 280MB/sec sustained of at least 30 minutes on a RAID 5.
I use it with the AXIO and was able to run 2 streams of uncompressed HD video with 1 layer of 3DDVE in realtime. The 3ware card is expensive, but considering using SCSI with 72GB Drives, SATA beats it by far in price and volume. I am not sure if you will be able to get the performance with only 4 drives unless you run RAID0 which is very risky. But be aware that Windows XP has a 2TB boundary, where the RAID card will split your drives into 2 or more 2TB volumes, but this does not deteriorate your performance. |
There is only one option if you want a GOOD controller, ARECA. The rest, 3Ware, Highpoint, LSI and Promise are just promises but no delivery.
But why a 4 disk (R)aid0 array when you quadruple the risk of disk failure and a complete loss of your data? I have recently posted about this with the links to an extensive comparison. Do a search and will easily find it. Daniel, this is the first I have heard about the 2 TB boundary under WinXP. Would that not be solved by using the right drivers on your hardware? For a software Raid configuration I can imagine that limit applies, but not for a hardware configuration. Can you explain this a bit further. |
Very Big Bad Boy
http://www.tweaktown.com/reviews/103...ion/index.html
VERY BIG BAD BOY - 12 TB storage and speed.... or even better....these guys... http://www.3ware.com/products/serial_ata2-9650.asp then you can have up to 24 multilane ports, delivering over 800MB/s RAID 6 reads and 600MB/s RAID 6 writes!! |
In all tests I have seen Highpoint, 3Ware and Promise always occupy the worst places and Areca consistently is at the top, sometimes even 100% faster than the others. |
That would be helpful to those of us with less expertise in this area. Then we might not suggest something less than the best...thanks. |
Only is Dutch, but the results speak for themselves:
http://tweakers.net/benchdb/test/191 and this thread may help also: http://dvinfo.net/conf/showthread.ph...456#post657456 |
