What exactly do capture cards do?
DeckLink HD Extreme like this one.
What is it they do? Why would it be worthwhile to get one? Would it make editing easier, faster? Could someone explain in laymen's terms how these work. I edit in FCP btw. Do they always capture uncompressed video? Do you need special drives or are sata drives fast enough? |
2. I edit on FCP also. You can capture from tape through component or SDI. In my case I capture from an HDV tape to different format (DVCPRO HD). You can also as I said before play back to monitor or to PRINT TO TAPE. 3. It could capture uncompress if you capture life from the component cables of an HDV camera or from a different format that recorded uncompress. 4. SATA drives are fast enough for compressed HD like HDV, DVCPRO HD, etc. For Full HD 720 or 1080 Uncompress you need at least a SATA Raid (a combination of 5 or more SATA drives that share the job load) I hope this answers your questions |
Douglas. I'm interested why you do this? I shoot in 25p and capture into FCP with the 108025p setting and it works fine. What are the benefits of your workflow?
You have to draw a thick line between capture cards and actual editors. Capture cards or I/O card will be a basic device that allows your computer to bring anything other than iLink (or Firewire) into or out of your computer.
Realtime editing cards or Video cards (remember the one you hook your monitor up to is a Graphics Card) have certain components on it that will help you accelerate things like compression/decompression, effects, transitions, etc. Check out the X2 card from matrox on the low end or the AXIO card on the higher end. Whereas you can do 2-3 layers of DV video with maybe 1 3D-DVE and a transition at the same time you can do (depending on your hardware) 7, 8 or more layers of Video with DVE's in realtime without the need to render. I just finished an edit with the AXIO where I had a "Brady Bunch" type 9 way split and then the videos flew out of the picture at the end in 3D motion. So I had 9 layers of Video with 9 layers of 3D DVE's and 9 individual disolves running all in realtime. That is the power only a Realtime Video card can give you. Whichever way you go or whichever platform you use, remember, you always get what you pay for! |
The layman's answer...
One big reason that you'll see people getting capture cards is that they need to import and export from or to things that don't have Firewire... such as a Beta deck. In other words, if you don't need anything but Firewire I/O you don't really need a capture card. If you do want to capture uncompressed you will need some sort of card (I have the Decklink HD Extreme) and you will also need a fast array. |
I'm looking into the Blackmagic Intensity HDMI capture card to capture uncompressed 1920x1080p from my V1. I have two 250Gb SATA drives connected by RAID 0 (so says the guy who built my computer anyway - but as far as I'm concerned, disc to disc copying is SLOW as!). Am I really going to need more than that to capture uncompressed? |
If you are thinking about capturing through HDMI what was recorded on tape, it will be heavily compressed 1440x1080 in 4:2:0 format and your disks are capable of handling that. But then using a simple fire wire would accomplish the same result. Where would the value added of the Intensity be? |
How does one set up a RAID array? When I bought the components of my PC and had it built I said I want RAID 0 and he said ok. But how do I know if it worked? And how do I add another 2 disks? |
The alternative is to use a software array under Windows, but that puts quite a strain on the CPU and is significantly slower than a hardware solution. The Help file will be a good source to start on how to do that. My experience is only with hardware controllers. To check whether your disks have been properly configured, go to My computer and check the disk size. It should be around 466 GB. Installing 2 disks is really easy, open the case slide the disks into the cage, use 4 screws to fix them in each slot, attach power and SATA cables. Just make sure you get the same model and size you currently have. |
Windows will see a raided array as one disk, not as two or even more. The major benefit of a (R)aid0 - notice the R is really not available in a Raid0, since it lacks redundancy - is the improved speed. With 2 disk the speed of the disks is nearly doubled, with 3 nearly tripled, etc. However the major disadvantage is that if 1 disk fails, you lose the data on all your disks. No sensible person would go beyond 4 disks in a (R)aid0 array because of that risk. Most prefer to use Raid 5 or 6 for arrays with multiple disks, because then if 1 or even 2 disks fail (in the case of Raid6) you can recover all your data. |
2 Attachment(s)
Does that suggest that they are 'joined' but still separated? I'm a complete layman with all this stuff... So am I right in assuming that (if Raid 0 is operational) I should have much faster transfer rates of files from D to E drive than to my system Drive? |
Your drive contains 2 partitions, one of which is called Stripe1. Personally I never partition my disks and the name makes me wonder whether it is indeed a raid0 or a raid0+1. I would explicitly ask your builder what he has done. Alternatively you could run HDtach or similar disk testing program and see what your transfer rate is. If it is indeed a raid0, the results should be over 100 MB/s.
On second thought, it does look like it is properly formatted as a Raid0, since fault tolerance is off. The name of the first partition threw me off. Windows does see at as one disk, but with two partitions. |
Bugger. Is HDtach something that is on my computer already or do I need to download and install it? |
John,
Here is the link: http://www.simplisoftware.com/Public...request=HdTach Run it on both of your disks and report the differences. Maybe I can figure it out for you. |
so when your editing hd you cant see what you are doing?
or am I crazy and read something wrong? |
4 Attachment(s)
I've attached the menu screen of the program, which shows that it detects D & E drives as one by the looks of things. I ran the test on D,E at 8mb and 32mb (whatever that means) and on my C drive at 32mb. But the results are all meaningless to me. Do they look right to you? |
John,
Your C drive (Seagate 320 GB) looks good with an average read performance of 58.4 MB and a CPU load of 3%. Your nVidia striped Raid0 (D+E), with 2x250 GB, gives 113.9 MB and a CPU load of 7%. As I said earlier, a 2 disk raid0 nearly doubles performance in comparison to a single disk and the results bear this out. The graphs show you that performance decreases when your disks get filled more than 60%. In automobile terms, your C drive is like a BMW 320, your stripe (D+E) is like a BMW 740 (faster and more room) and you realize of course there is a model BMW 750L available that is even faster and offers more room and comfort, albeit at a price. Your mobo has an nVidia chipset, I assume, and it does a very decent job of striping, although it is not up to Areca in terms of flexibility and CPU load, but then Areca is rather pricey, and the chipset is on-board. Like the difference between the BMW 740 vs. 750L. I think you are all right with your configuration. Hope this helps. |
Harm, how much lower than 7% would the Areca's CPU usage be with a 2 disk RAID? That doesn't seem bad for 113.9MB/sec.
Eric |
Eric,
With an Areca ARC you could expect the CPU load to be around 4% or even lower. Here is a recent overview (albeit in Dutch): http://tweakers.net/benchdb/test/191 As you can see from this overview, the A/V Storagemark 2006 results for a 2 disk Raid0, using WD 74 GB disks, gives an index of 247.7 with the nVidia nForce Pro 2200 but with an Areca Arc 1160 with the same disks it results in an index of 385.7. Significantly faster. BTW, a single WD 36GB Raptor has index 100. Missing in this list are the results for the newer Areca ARC 1231 ML card (PCIe), that utilizes the 341 IOP chip, instead of the older 331. This card will outperform the 1160 (PCI-X) by a wide margin. The A/V storagemark 2006 is a weighted average of various A/V applications as indicated in the link I gave you. Hope this sheds some light. |
Thanks for the info, Harm.
Is 4% really that large of a difference though? I mean, sure every little bit of extra power helps, but 4% seems pretty minimal. Is that including the usual 0-2% cpu usage when sitting idle too, or just hard drive cpu usage? Eric |
Eric,
Every tiny bit will help, but it is more a question of how all those tiny bits add up to make a significant difference. In this example of nVidia versus Areca, 247.7 versus 385.7 (more than 50% faster) it is the combination of CPU load, cache size, IOP chip, the embedded software (ICHx-R version), etcetera that make this quite a sizable difference, even though the disks used were the same. When looking at the list I linked to in a previous post, for me the most notable thing is that Areca HBA's are consistently at the top, while the better known brands like Promise and Highpoint are below average performers. |
Cool, thanks for the info. I didn't study the numbers too carefully but since you pointed it out like that, yes, that's quite a bit better, and using less CPU power in the process is a good trick! :)
I need to build a new desktop system to replace my Barton 2500+. I've been doing everything on P4/3.46GHz laptop for the past 2 years because it's faster than the desktop. I'll check into these boards. Are they available in the US? Eric |
Yes. Since I don't know if it is OK to mention name of outlets that sell these, I suggest to do for instance a search for Areca on TomsHardware and you will find many links to shops that have them.
Cool, thanks, I'm quite familiar with Tom's Guide.. :)
