pivot too narrow
I made a jib arm that rotates on a vertical pipe, but the pipe is just a bit too narrow for the socket - there's a tiny bit of rocking motion..
any suggestions on adding thickness to the pipe - something to wrap around it or coat it with? I think duck tape is too gummy and soft. I saw some metal tape which is a foil backing on butyl adhesive, but it seems a bit soft too. I thought maybe a wide teflon tape wrapped around it would be tough and smooth, but I can't find any teflon tape except the 1/2" used for plumbing... inventors and craftsmen (women) - any ideas? (later) I realized I hadn't searched for wide teflon tape on the internet - and so I did and found some! http://www.cshyde.com/Tapes/Data/fatPTFEinfo.htm although an initial browse on their site shows most of the links and pages not available. :( (more) I found this site - http://www.westcoastplastics.com/HTM...n-adhesive.php - that has 4" wide teflon tape 5 mils thick...but in 36 yard roll for $250/roll! too much!!!! then I found this one - http://www.qualitymatters.com/ARY-Va...mar-979822.htm - and the 3.5" wide teflon tape is available by the foot. Just need to find out how thick it is... |
