May 9th, 2015, 02:48 AM | #1 |
35mm Cine and Full frame Vintage lenses on GY-LS300
I have made some 3840 x 2160 24/30p footage to share here.
1st: Canon Cinema prime lens 24mm EF mount Best regards Stewart Hong Kong |
May 12th, 2015, 09:36 AM | #2 |
Re: 35mm Cine and Full frame Vintage lenses on GY-LS300
Should I assume you used the "Cinema Subdued" setting on this footage?
Jim Martin EVSonline.com |
May 14th, 2015, 08:57 PM | #3 |
Yes Jim,
then no further color grading or image adjustment from the master files in the SD card, and just the way it looks from the master. I had shot some footage with my " angenieux " full frame ( 90mm F1.8 ) on the JVC booth at NAB 2015 as well. https://www.facebook.com/photo.php?f...type=1&theater Will share here soon. Cheers, Stewart Chong WOW Holdings Limied Facebook : Stewart Chong |
June 25th, 2015, 09:28 PM | #4 |
Any problems with the adapter for EF lenses on this camera?
I was thinking of getting the FS7 until I learned that the adapter defaulted to a 'green' mode every time you change a lens and had to be reset. Do you use the Metabones adapter and does it have this wierdness? |
