How can you overcome the file limitation size with the HM200? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC 4K Pro Handheld Camcorders
GY-LS300, GY-HM200, HM170 and HM-Q10 recording 4K Ultra-High Definition video.
Old March 5th, 2016, 04:31 AM   #1
I have recently bought the HM200 but am increasingly frustrated by the inability to over come the 4GB (10 min) file limitation. I have set it in the menu, am using 128gb transcend SDXC U10 cards formatted in the camera, and yet I still get split files. When these files are put into Vegas there is a noticeable gap between the files. I need to have one continuous file. With my Sony ax100 camcorders its simple, download using Sony Playmemories and all the files are joined into one. Why can't other manufacturers do the same? Is there some other software that will download and stich the JVC files together. If not then where is the point of these cameras?
Please help otherwise I have bought an expensive white elephant. I have an important shoot coming up and want to use this camera as it looks a bit more professional than the AX100, but I can't have split files with a noticeable jump when they are put together.
John Hume is offline   Reply With Quote
Old March 5th, 2016, 05:40 AM   #2
Re: How can you overcome the file limitation size with the HM200?
Hi John,
Did you not have a disc supplied with the camera with proprietary software specifically for that purpose? I don't use JVC, but certainly my Panasonics all came with software for downloading the footage from the camera with seemless clip joining. If you don't use the supplied software, some of the embedded information may not be transferred and you will drop some frames. There may also be third party software available but others will know more I'm sure.
Roger
Old March 5th, 2016, 08:33 AM   #3
I never understand why in this day and age we still use this fat32 format.
Donald McPherson is offline   Reply With Quote
Old March 5th, 2016, 09:24 AM   #4
On the Mac side there is a great, fast program called EditReady that can stitch the files together and retitle them if you want. On the PC side I am sure there is something equivalent. Make sure to choose "Re-wrap" when making the files so you are not recompressing the files.
Edit/Camera/DCP production/Animation
Old March 5th, 2016, 01:11 PM   #5
Originally Posted by Roger Gunkel View Post
Hi John,
Roger
The only disc supplied just had on it the complete manual. No help at all. Beginning to think that JVC is just a joke.
Old March 5th, 2016, 01:12 PM   #6
The cards are actually formatted as exFat so shouldn't have any limitations but am still getting individual 3.45 clips and not one complete clip.
Old March 5th, 2016, 03:56 PM   #7
My gy ls300 also records in 09:46min pieces but when I add them in Edius and place these separate files against eachother there is no video or audioloss, is it a quicktime or avchd codec you are using? And are you using the latest version of Vegas?
Old March 5th, 2016, 04:09 PM   #8
Are you also letting Vegas take them off the card/camcorder or are you inputting individual files ? AVCHD is FAT32 length files whatever the card file format. You can use Device Explorer under the view menu to import clips from your camcorder. I have all Sony's so cannot confirm whether this will work for your JVC. Import programs need other files on the card to correctly join clips together so just grabbing just the files will not always lead to good results sometimes missing frames or audio. !!!
Ron Evans
Old March 6th, 2016, 06:21 AM   #9
Hi Ron. Like you uptil now I've have been all Sony which work fine. We also seem to film the same sort of shows and events and have often read your comments and agreed with them.
I now have 3 AX100's and a CX100 for filming shows and whilst I use them in the AVCHD format they will also record Sony's XAVCs format and there is no file size limitation on this.
I thought that this JVC camcorder would be similar. Yes the AVCHD files would be split into 2gb segments but I did expect to be able to put them onto a timeline and for them to run sequentially, but this doesn't seem to happen, or that JVC would, like Sony with Playmemories, provide some simple software that would stitch the clips together.
The other surprise is that the .MOV formats are so difficult to work with. My Vegas 12 crashes when I try to play them on the timeline and the 4.2.2 YUV won't import at all. Quicktime doesn't play these files either, only the VLC player. Seems to me that JVC only care about Apple users who have FCPX.
I bought the camera as it looks a bit more professional than the AX100 for commercial use but it is pointless if I can't actually edit any files. I was also tempted by the ability to stream directly to YouTube but now not sure how useful that it is going to be.
Really wish that I had stuck to Sony and bought the NX100 as at least that would have fitted in with the AX100s.
Old March 6th, 2016, 06:26 AM   #10
Hi Noa
I'm using Vegas 12. Vegas 13 didn't offer me anything extra so I didn't bother upgrading. I can't seem to get Edius onto my computer as the downloader says that I need a couple of Windows updates and Windows says that I already have them so I go round and round in circles and Edius refuses to install.
Which recording format are you using? The main problem seems to be with the HD 50M YUV 4.2.2 as nothing I have, except the VLC player recognises this. The 50M XHQ will import into Vegas 12 but the program crashes when I try to play it on the timeline. I haven't tried the 4k yet.
Old March 6th, 2016, 06:32 AM   #11
My ls300 has the same codecs as your camera but I don't have any issue with the codecs this camera uses, neither in playback or while editing and I am using edius 8wg on windows 7pro. I just tried to import a few jvc files into after effects and that also is possible.
Sorry that I can't give you any other advice.
Old March 6th, 2016, 06:55 AM   #12
I know this would be another step but have you tried getting TMPGenc to convert to another format for you to use. I know EDIUS had some issues wanting updates and cannot remember now what the resolution was to solve that.
Ron Evans
Old March 6th, 2016, 07:12 AM   #13
There definitely is something going on with jvc codecs because this is not the first user I see complaining about workflow issues, not sure though if it is jvc responsibility to assure it works in every NLE, it's like the samsung nx1 that had the h265 codec when it came out, there it also was the NLE manufacturer that had to update their software to make it work natively. My experience with Edius is that they take their" edit anything" slogan more seriously then some other NLE"s. I have shot in HD and 4K using it's available codecs and it's just matter of dragging and dropping the files straight from the card onto the timeline, it all just works for me. I know this is not helping John much but it's just to show that it can work.
Noa Put is offline   Reply
Professional Video
(800) 833-4801
Portland, OR
New York, NY
Z.G.C.
(973) 335-4460
Mountain Lakes, NJ
Abel Cine Tech
(888) 700-4416
N.Y. NY & L.A. CA
Precision Camera
(800) 677-1023
Austin, TX
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC 4K Pro Handheld Camcorders
Google
1998-2017 The Digital Video Information Network
