LS300 Spot Metering
How does one change the spot metering mode? Apparently there are four, but how to select?
Thanks |
Re: LS300 Spot Metering
Four?
If you press and hold the function button to which you've assigned spot metering, and then try pressing it a few times it toggles between various modes. |
Thanks Duncan. I think the four are: Max-Min/Max/Min/Manual. I've managed to get into manual, but now the press-hold-toggle no longer works, so I'm stuck there. I'll try a reset.
Update: A camera reset got me back to the default Max-Min, but I haven't mastered the trick of cycling through the other options. |
Here's a link to a JVC update to the LS300 user manual which describes the new spot meter features:
http://pro.jvc.com/pro/attributes/4k...LS300_v2.0.pdf |
