June 27th, 2017, 07:10 PM | #1 |
Sensor Has Dirt In The Module
So I notice while scrubbing through the footage that I have dirt inside the sensor module. I thought it was a lens until I put the lens on the other LS3. I sent it out to the nearest professional repair shop to get it cleansed and they were unable to clean it. I was told that the module is seal close with no way to get inside of it for cleaning. I will have to send back to JVC and hope they do not tell me I have to buy another Sensor module. Has anyone else tried to clean the sensor?
June 28th, 2017, 10:34 AM | #2 |
Re: Sensor Has Dirt In The Module
Not sure I understand the issue. If you are talking about dust on the sensor's protective glass, it is all readily accessible once you remove the LS300 lens mount cap. Just like a digital still camera. Is there something between the cover glass and the sensor?
June 28th, 2017, 01:03 PM | #3 |
The sensor module is said to be sealed and you can not open the sensor module once you remove it for the camera. So you can not get to the sensor because the protective glass is the top part and the sensor is the bottom and they are manufacturer sealed together. the tech said that they must have used an epoxy or something similar.
June 28th, 2017, 03:22 PM | #4 |
Since the problem is foreign objects getting inside the "sealed" sensor stack I would think JVC would be very interested. Sounds very much like a manufacturing defect. Possibly they will give you a courtesy repair.
June 28th, 2017, 04:13 PM | #5 |
Did you not see this right after you got the camera? Those are some very obvious dirt spots, it's hard not to see them.
June 28th, 2017, 04:27 PM | #6 |
Could it be dirt on one of the ND filters?
June 28th, 2017, 07:32 PM | #7 | ||
I can say with out the ND's active the dirt was there. But it could have come from the ND's though. I will habe to check and see if the NDs are inside or outside the sensor module. If they are outside of the module then it is not possible. Last edited by Aaron Jones Sr.; June 29th, 2017 at 10:47 AM. |
July 18th, 2017, 01:41 PM | #8 |
Ok, so I sent my LS3 in to JVC and just got it back today. It turns out that they had to replace the sensor assembly. The cost was $2950. Thank God for warranty repair. I have attached the part listing that I found online.
PacParts: JVC MP2-0607-00 |
July 18th, 2017, 03:14 PM | #9 |
Glad JVC covered it and you have it back
July 18th, 2017, 08:55 PM | #10 | |
Aaron - It's good that it got fixed without having to pay for the part.
Anyway, more details from the repair facility would be helpful. Edit: one could almost buy a new cam for what the part cost (if you had to buy the part). |
July 18th, 2017, 09:27 PM | #11 | |
July 19th, 2017, 01:24 AM | #12 | |
