JVC GY-HC500 codec question at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > JVC CONNECTED CAM Series 4K Camera Systems
JVC GY-HC900, HC550, HC500 series 4K camcorders plus associated peripherals.
Old April 21st, 2019, 04:31 PM   #1
The specs for JVC's new HC500 camcorder JVC Pro Specifications indicate the camera only records ProRes in the 4K UHD format. HD (1080p) is recorded in a H.264 format. If this is in fact correct, bummer. I would prefer to be able to record HD also in the ProRes format.
W. Bill Magac is offline   Reply With Quote
Old June 5th, 2019, 10:22 AM   #2
Re: JVC GY-HC500 codec question
No one has responded to this question, but from a minimum of checking it seems that ProRes is in fact only available in 4K ( and I assume UHD) with this camera... But that's okay, since it's easy enough to edit with and export as 1080.
On a related sidenote... Now that JVC has apparently purchased rights to the ProRes codec, wouldn't it be a nice surprise if it was offered as a firmware update for the LS-300...
Steve Rosen is offline   Reply With Quote
Old September 15th, 2021, 04:04 PM   #3
The limitation with ProRes is that one needs to record to the SSD -- ProRes won't record to the SD cards, which are limited to H.264.
Recording ProRes in HD (1080p) simply requires setting the System to "HD EXT(SSD)" according to page 57 of the user manual.
Earl R. Thurston, Stargate Connections Inc.
Made with GY-HD100: The Container Adventures: The Rescue
Earl Thurston is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > JVC CONNECTED CAM Series 4K Camera Systems
