JVC Everio HD7
I read a lot about the JVC Everio HD7 camera. But still I am not sure about on thing. Apparently this cam shoots only in HD. But can I get standard definition Pal Dv (I am in Europe) out of the firewire port to capture it on my PC as we used to do with the normal digital cameras? Hope that someone can give me an answer as this is the last thing I wish to clarify before buying it. Many thanks
Anyway, getting back to your question. The HD7 has a down convert function to get SD out of the camcorder. Actually, you want PAL DV, so you want the HD7E model. If you engage the down convert, SD PAL DV outputs via the firewire. If you don't, HD outputs via the firewire. However, it's unknown that any editor, except for JVC's supplied cheapie, will work with this different flavor of MPEG 2 compression. If the very limited editing controls are enough for your uses, then this camera might be okay for you. |
I read many reviews on this cam and all seem to agree that it is difficult (if not impossible) to capture on pc the full HD of this cam. However for the time being I am mostly interested in capturing standard definition DV via firewire, by using the downconverting mode. If I do so, will I still encounter problems to capture dv on my pc by normal editing software? And will the quality of the downconverted video be equal to that of a similar camcorder which is shooting in standard definition (non HD cmera)?
Moved from Open DV Discussion to JVC Everio forum.
Personally I record in 1440cbr for output to sd, this gives me room in edit to reframe...we do adventure stuff where the subject doesnt alwys end up being as close as we'd like or in the right place. Also leaves me with 720 HD source. I dont use firewire, just drag the files from the D7 to the pc over USB2.0. The JVC .tod files read straight into vegas, though it was a struggle getting there
The Sony 1000 is 10X bigger and likely without the HD7's exposure controls. |
I assume you need "less than" HD because your editing package is not able to mix HD with older footage. Because I dont have any legacy footage I can just use whatever is common and popular and start my library with HD and downsample to the required resolution (as far down as H.264 for YouTube). If you are starting from fresh then I would trust the members online to guide you as they cover all of the main topics. you just have to decide on Mac or PC and which editor you prefer. |
