JVC's New HD6 1080 60p
Hi
I have a ? The new HD6 records in 1920 x1080i the same as the HD7 but outputs in 1080p 60fps. Is that right . I was looking over the spec sheet. I would have thought it would record in 1920x1080p60 and out at 60fps but that is not so. and they also made a statment that the VD-40 unit will output it at 60p also. So if the file is stored at 1080i the camera outputs it a 60p and the VD-40 outputs the file at 60p is that the same ?? as if the footage was from the HD7 out putted on the VD-40 ???? and the VD-40 would play it at 60p? Len, hope that made sence ! |
I saw the press release and i get the impression the 60p HDMI output is for viewing on 1080/p monitor. The .tod files are most likely 1080i. I'm not aware of any edit system that supports 1080/60p.
I think all the chips and boards are the same just different programing. Save money, cost less, make alot of different models in HD, just don't give them what they want. always leave something off. Just play with us JVC !!
Len |
...and these are .25 inch sensors?
Now if we could find an EZ way to create the files that can be written to the camcorder's disk one could buy an HD5 just as a player. :) The fact is that ALL HDTVs convert I > P. The best deinterlacers do exactly what the deinterlacer in the camcorder does. This a bogus feature. Shame on JVC. |
Hi
Thanks Steve, that is what I was thinking , but was not sure. I also have your Hand book. Great work ! Thanks for you time on this site and your Hand Book . Len |
In fairness, however, the material presented in Japan makes it very clear the chip used in the camcorders is the same as used in JVC's new HDTVs. So the Japanese consumer is more likely to get all the facts and be able to understand them. Outside Japan, however, the marketing material will be taken as "fact." Think of how the current brochure describes the advantages of OIS -- yet EIS might well work better than the camera's actual OIS implementation. So I'll reserve judgement until I see the brochure. If it makes it clear that this feature is for those that have HDTVs that, unlike JVC's HDTVs, do not display clear MOTION -- then I don't see a problem. By the way, many HDTVs are unable to correctly deinterlace 60i. JVC is one of the few companies where ALL of its HDTVs do it correctly. PS: The other point that must be made in the brochure is that this feature does nothing for those who edit. |
In fact, that was my initial bafflement upon reading the JVC press release about 1080p/60 capability -- how are people going to edit that stream? The answer, evidently, is that they aren't. I hope that the brochure will be as candid and educational as you have outlined. But if this were a wager, I'd bet the other way. ;-) |
Any reviews yet?
Has anyone put their hands on one of these (HD5/HD6) yet? All the info I can find is just regurgitated cut/paste from JVC's press release.
I'm going to buy a HD/HDD camcorder soon, but would like to know if there are any improvements made to the HD6 over the HD7 besides HDD capacity (like OIS, software, interface or image quality) |
I was planning on the HD7 (I really like the manual focus option) especially now that the price has dropped. I was just curious about any "major" improvements to the newer models. If the only difference is smaller size and larger HDD capacity, I'll get the HD7 (since MF is eliminated on the HD5/6) It never fails, just as I'm about to invest in some $$ gadget, they release a "new and improved" (and more expensive) version, although in this case, it appears they only shrank the housing. The only drawback I see (which seems to be true regardless of brand) is the "10X" zoom still leaves you with a wide shot, I'd really like to see more of a telephoto zoom lens. |
See my all videos here: http://vimeo.com/user318721/videos Send your feedback/suggestions if you likes or not! Kaushik |
Would a lower resolution make for smoother high speed movement? I turned off the HD in the window, but that only increased the pixilation. |
Kaushik |
