720p50 to dv-pal
Hi!
I have done a documentary shot in 720p50. One of the places i deliver to needs to get it on DVCAM. So what is the best way to go from 720p50 to dv-pal. I tried via compressor to make a dv-pal compression. But it looks a bit jittery. I think it is because of the conversion from 50 fps to 25 fps... Any ideas how to do it right?? |
Hi Henrik,
What kind of software did you use, as it otherwise is difficult to help. And PC or Mac? In theory this should be very smooth in DV-Pal, as it also has 50 frames but interleased instead of progressive. If it looks like 25 frames you need to tweak a setting in your software. |
Yes please
can someone help with this. I just shot an event using 720 50p, thinking good slow motion, good with fast panning, didn't think how to get it on a DVD in PAL land, as I'm not really strong with my post work yet.
Thanks in advance Adam |
System
I am working on FCP the latest edition. I also thought it should be very smooth - but all the motion is jittering. |
Hi Henrik,
I have no FCP, so I cannot help you further with this one. I personally use the HDlink software from Cineform to convert the edited files. |
Anybody else??
Does anybody else know the best way?
I ended up putting it out to betacam though my KONA card where the card downconverted for me realtime - this looks fine. But if I had to go through firewire to my dvcam machine. What would then be my sequence or compressor setting to get a fine result to convert from 720p50 to DVCAM 25 fps |
