help needed with record on DR-HD100!!
Hi.
One question. If I record with the DR-HD100 on the JVC there is blinking a "y' in the display on the JVC Also the HD-100 is blinking, blue and magenta. What does that mean? Thanks in advance. regards, Johan |
Hi Johan
When the Y is blinking your in the pause mode also when the Dr hd100 is blinking you are also in the pause mode when the y is soild your in the rec mode the Dr hd 100 will also be soild and in the rec mode. Joe |
JVC and HD-100
Hi Joe.
Ok, is that all> I thought that was something wrong. Thanks, Johan |
Johan,
would probably be a good idea to read over the user manual. |
"If all else fails, read the manual." Don't worry, I'm also the kind of person that fumbles for a few hours and then reads the manual... |
