HDV sd60p format
I'm trying to capture some footage for slow mo that was shot on a JVC GY-HD110 using the HDV SD60P format.
For capture/editing I'm using Final Cut Pro 6. I've captured 720/24p footage with this camera and everything works fine. I'm thinking that the Project / Sequence / Capture settings are matching the footage format. The camera (VTR) is recognized and can be controlled (ie stop, play, rewind, etc), but when I press play in the capture dialog, there is nothing on the preview window, nor does anything show when I select "capture now" I created a new project called slowmo For sequence settings under the GENERAL TAB I've have: Frame Size: 1280 x 720 with HDTV 720p (16:9) selected Pixel Aspect Ration: Square Editing Timebase: 59.94 QT Video Settings: I've tried Apple Intermediate Code and HDV720/60p Under File > Audio/Video Settings I've used HDV as the Capture Preset and HDV FireWire NDF as the Device Control Preset. I've also created a copy of the HDV Firewire and changed the frame rate to 29.97 (can't find one that can be changed to 59.94) Any thoughts? |
Unless I'm mistaken, on the 100 series the 60p option is DV encoded using the HDV encoder so the footage isn't 1280 x 720. It's 720 x 480. This is probably the root of the issue but someone is sure to come along shortly with a more complete answer.
yes its SD resolution but i can add that while its 480p it can intercut well with 720P footage if used sparingly.
It has been known that the SD resolution of the JVC is better than DV sd codec. Ted |
I can only speak from the side of the dreaded, despised or admired Premiere Pro side of the ditch, so my words are probably heresy to the max to FCP purists and the music of heaven to Adobe users? To make matters even more aggravating on a JVC thread, I used Sony HDV and Sony MiniDV.
("music of heaven" = too much?? - maybe I am simply so far up myself as to see the light - never mind - suitably self-chastened - let's move on.) I found when I wanted to mix SD MiniDV and HDV on a music video in a multicamera style presentation, that I had to create a separate project for the SD footage, set the capture preferences for MiniDV, do my capture, save and close the project after noting where the captured MiniDV file had gone. I then opened my HDV project, imported the MiniDV file, selected the MiniDV clip and dragged it onto a video track. In the playback presentation it initially appeared as a postage stamp on a larger image. In Premiere Pro 2, there is an option for scaling to frame size so that the MiniDV occupies the same frame size as the HDV images. In my case it was more complex in that I had elected to keep the 4:3 frame in MiniDV for resolution reasons. I also elected to keep black edge bars on the 4:3 footage in the 16:9 frame for resolution reasons. Once all the cuts across camera views had been done by razor and extraction from each of the tracks, the clip was exported and it worked fine. Of course while scaled correctly for vertical height, vertical black edge bars remained for the 4:3 footage but as the auditorium was blacked out anyway, it did not matter as the master wide view was largely black with performers on stage spotlit in centre. My imagining is that FCP offers the option of importing a separately captured MiniDV file and rescaling that on a HDV timeline. Hopefully I have not confused you or worse, sent you down a deadend. |
After re-encoding your m2t to Quicktime then BATCH CONFORM to 23.98 in Cinema Tools. You'll then be good to go. You can look at the last 1/4 of this podcast to see the process. http://www.dvinfo.net/prohd/Bonus_1.html |
