Thinking out side the Square (tapeless capture)
Hello,
I have a question, If i buy a high speed Fire wire (800) Card reader and a 16 or 32 gig card, will it work if i plug it in to the firewire port on the HD 201 camers and try to record to it. Lexar - Flash memory card readers - Pro CF Reader Just a question. |
Unfortunately no. There needs to be some sort of intermediate DOS to write the m2t stream to the card.
JVC showed a mock-up of the MR-HD200U at NAB08 using SD cards but I haven't heard any news about it since. JVC News Release - MR-HD200 |
MR Hd 200
Will this unit be able to record from the Hd SDI conection or is it just like the HD 100 and record only DV and HDV, through the firewire port. I would like to record uncompressed with my HD 250. Are there any cost predictions.
It sounds like you are looking for either Convergent-Design's Flash XDR or NanoFlash for lossless mpeg2 encoding from HD-SDI using intraframe compression (no GOP.) Download the uncompressed vs intraframe mpeg2 high bitrate sample from the website. They ran a difference filter in photoshop to detect possible compression artifacts and the two are indistinguishable. |
Dam,
Well lets hope some one smart can write some code or software to add to the card. Thanks any way tim. Rob. |
Hi tim,
What type of Tapless do you recommend, i will still always capture to tape, the tapeless capture it would be used for a quick capture to my laptop for a same day edit. (now that we have Clipwrap) I have a HD201. Thanks Rob . PS I will not use it all the time so there fore did not want to send to many $$ |
I haven't used any of the other options in a day-to-day production environment. nNovia products look promising but I'm not sure how they are priced. Josh Chesarek has done a first-impression review here Review: nNovia QuickCapture HD and Small Camera Mount by Josh Chesarek |
Daniel Weber |
tim, can you tell use how many minutes the fat32 2gb limit on clips amounts to? I'm seriously favoring the dr hd100's slim design v.s. the bulky nNovia qc hd.
