Show Reel shot with HD100 & HD200
I conducted a seminar this morning and had to whip up a new reel with more recent works last night, 99 percent with HD100 and HD200. Some scenes were created either in a 3D world or a compositing environment.
A mixture of stock lens 16x footage and footage with lens adapters of either 35mm and mid format. Theres also scenes with 35mm mounted onto the cam via Zoerk adapter. I thought I'd share it here to show the JVC cams' versatility in different situations. Heres a link. Ted Ramasola Show Reel 2 By Ted Ramasola On ExposureRoom |
Great showreel Ted...how do you learn to do all that stuff?
Hi Ted.
A lot of great shots in your reel but I'm not feeling the edit much. It seems to be very evenly paced throughout with quick fire shots, which are great when you have somewhere to breathe every so often, I hope you know what I mean! I also think you could loose about 45secs and it would be stronger because of it....just the less is more equation on that one I think. Great work Mat |
The problem I see with the reel is that there are not enough women in it ;-)
Solid work Ted. |
Thanks for the constructive and encouraging comments guys, given the time I had to whip up this reel I do feel that its still needs a lot of trimming down.
I'll do some reedit on this stuff after I'm done with this current project I'm doing right now. I'll post when it's refined. |
Reel now contains all HD footage from HD100/HD200
Finally got the time last night to do some work on my reel, I removed the SD uprezzed scenes and retained only HD. Even the video texturemaps of some 3D logos were from the JVCs.
Please tell me what you guys think. Ted Ramasola Showreel 2 By Ted Ramasola On ExposureRoom Quote:
You got it right, I tightened it and added some scenes from a current project. I think I actually dropped around 45 secs or more. |
