Saving scene files
How do I save Dashwood's scene files so that I can load settings in the field?
i think i got it... manually set the parameters then save scene file to SD card. Once there, i can "load" setting from card....sound right?
Details on how to save, file names, etc. are in the first post of this thread:
http://www.dvinfo.net/conf/jvc-pro-h...scn-files.html In the same post, a little further down, are "zipped scene files" you can download and put on SD cards according to the directions earlier in the post. Since each card hold only four files and must conform to exact file names, it is necessary to keep documentation of which scene files by which of the four names exist on each of the SD cards you may be using to store and use the scene files. You can just use the "recipe" for a scene file and manually input the setting, then save the file, but this is the long and cumbersome route. |
