Fujinon 16x lens tight focus ring
I have a JVC HD100 with stock lens. Last year the focus ring became tight as a I got toward infinity. It still works, but its much looser at the the closer range. Someone told me I could ship it to JVC to repair it, but I think that would take too much time. Has anyone had this problem before?
The 16x fujinon on my JVC HD110 has a plastic frony barrel. If I clamp a mattebox onto the front ring, it distorts enough to bind. It is necessary to have a metal ring screwed into the plastic barrel to mitigate distortions when using a mattebox.
Lens Barrel
I think you're right Bill. I looked at my lens barrel and it looks a little distorted. Do they make metal rings to fit over it or is this something you made?
-Clay |
buy one of those metal filter adapter rings to screw into the front of the plastic
Century makes a ring for the JVC 16x lens to stiffen the barrel when adding a century wide angle adapter:
CENTURY 82MM 100U RING - Schneider Optics However, a UV filter (preferably one with a thicker edge to give more support) or an adapter ring as Bill suggests is cheaper. |
