Fitting GY-HD101E into a Kata CC-195
I bought a CC-195, and trying to work out the best way to fit the camera in.
It doesnt seem as good as the picture/text make out on the product documentation.... Using the supplied 'lens cushion' means the camera isnt level/stable, and the mic sticks out the top. Any pictures/suggestions would be ace. Cheers |
I have squeezed my HD100 (with Anton Bauer adapter) into a Kata CC-193, which is a bit smaller than the CC-195. This worked well as a airplane carry-on.
Basically, I removed the battery and the A/B Firestore bracket. This gave me a snug fit, with the stock 16x lens still attached. If I left the viewfinder attached, but pushed in to its closest setting, I could -- just -- close the zipper. However, I was worried about pressure on the viewfinder, so I ended up detaching it and stuffing it next to the lens. My recollection is that I wrapped the A/B bricks in the Kata velcro dividers and put them on either side of the body of the camera to provide some padding on either side of the camera body. Then I just cinched the strap tight around the body and left it at that. I didn't do anything special for the lens, as it was a snug fit front-to back. Worked fine as a carryon, but I wouldn't use this setup if you were going to let baggage carriers or TSA handle the camera. I would think with the 195, you'd have a little bit more room to work with. You might need to stuff some cloth or chamois around the camera to pad it a bit. |
Thanks Brian
I think the key is to remove the mic - but the promotional pics... show the cam, viewfinder, mic and even the additional battery pack/firestore attachment on. http://www.thebackpackplace.com/file...aded/cc195.jpg |
Are you using the stock mike? I left the mike on and it worked O.K. I have a Rycote dead cat on mine, so there was a bit of extra padding.
I think you can either take off the mike or the viewfinder. Either one will probably give you a bit more room side-to-side. You could try it without the "lens cushion." The CC-193 didn't come with one. |
I use the Kata BP502 for my HM700, I think this will be the best solution for all JVC ProHD-Cams.
