JVC/Fuji Wide Eye FOV Comparisons
I finally received shipment of my AB mounts, Swit batteries/charger, and the Fujinon WCV-82SC Wide Converter. It has a factor of 0.82, so the wide end on the stock lens becomes equivalent to 4.5mm.
The nice thing about it is that the lens hood still fits perfectly, and the outer dimensions are still 83.5mm so my Cavision matte box will still fit fine. It also seems to be completely zoom through capable. I made no focus adjustments when changing focal lengths. Here are some comparison shots with the stock lens at various focal lengths. (5.5mm, 20mm, 40mm, 88mm) Here's a zip of the jpeg frame grabs: http://homepage.mac.com/timdashwood/...omparisons.zip Tim |
Much appreciated, Tim! Many thanks,
Now that you've had a few days with it, is the wide converter worth the price? Any recommendations?
I'd say it makes quite a difference. The images are not degraded either.
I must confess I'm impressed. Quite a difference and full zoom capability. I can't find the 5.5mm shots on that zip. What are the DS_STORE_files?
Tim, does it have any influence on CAs?
Anytime you see "Stock16x" instead of "WCV82SC2" in the filename it is "without" the wide eye. .DS_STORE is a hidden file in MacOSX/UNIX for "directory structure" that shows up sometimes in a zip file. You can trash it - it contains no data you need. |
However, I would say that it is worth the price for a intermediate solution to buying the 13x3.5 lens. I still intend to pick up the expensive lens when it is available and I have the budget for it. |
To buy the 13x lens outright.
The cheapest place I've found is expandore for the 13x lens.
http://www.expandore.com/product/JVC/HDV/GYHD1000.htm They list it at $8040 BTW: I didn't see the 5.5 either. Maybe I can't see it because you can't use an asterisk in a Windows file name? |
The new zip file: http://homepage.mac.com/timdashwood/...omparisons.zip And here are the individual jpegs: Stock lens 5.5mm: http://homepage.mac.com/timdashwood/...m_Stock16x.jpg Stock lens with .82 Wide Eye at 5.5mm: http://homepage.mac.com/timdashwood/...m_WCV82SC2.jpg Stock lens 20mm: http://homepage.mac.com/timdashwood/...m_Stock16x.jpg Stock lens with .82 Wide Eye at 20mm: http://homepage.mac.com/timdashwood/...m_WCV82SC2.jpg Stock lens 40mm: http://homepage.mac.com/timdashwood/...m_Stock16x.jpg Stock lens with .82 Wide Eye at 40mm: http://homepage.mac.com/timdashwood/...m_WCV82SC2.jpg Stock lens 88mm: http://homepage.mac.com/timdashwood/...m_Stock16x.jpg Stock lens with .82 Wide Eye at 88mm: http://homepage.mac.com/timdashwood/...m_WCV82SC2.jpg |
Tim,
I can't seem to find the converter in stock anywhere. Where'd you get yours? |
