Still having motion blur problems
Anone can help me getting rid of the motion blur when I pan and tilt using either the tripod head or job etc. I'm getting the "video blur" when I pan sometimes. I even tried to set the shutter higher to see if that worked, but to no avail.
Please help. I hate seeing shots looking like video.. =( |
Is motion smooth turned on?
Yes it is turned on.
Should it be off? and if so, why, and when should it be off? and when shopuld it be used and on? Any insights? PS> How is your project going? |
Personally, I would never turn it on, but that it a subjective opinion based on the fact that I purchased the HD100 to emulate the look of film and nothing else. I don't use 720P30, I don't use a 1/24th shutter, and I don't use motion smooth. BTW, has anyone watched the trailer for "Miami Vice?" It looks like Michael Mann is using slow-shutter again to gain an extra stop in sensitivity, just like they did in Collateral. So now we have another big budget feature film that has the streaky tell-tale "video" look. http://www.apple.com/trailers/universal/miamivice/ Quote:
Like yourself, my sole purpose for getting the HD100U was for getting Film Look material, not video, so I will be shutting of the motion smooth for good =)
Also, do you know how to adjust color bars on a monitor to get accurate colors? I just got the new HD Marshall monitor for the HD100U and I want to adjust the colors correctly. Thanks Tim... When can we see some of your recent material? |
Add your email address to your profile and I might send you something. |
double clocked
A question for Tim,
In the other post about strobing you said the live output is double clocked which gives an incorrect guide as to what is recorded to tape. However you said this also has its advantages. I was just curious as to what these advantages are. Regards Greg C. |
Tim I changed it. I never had it for some reason. I do now. You can always contact me at duke@superbadmusic.com
Calibrating My Monitor
Manny |
my strobing here today gonr tomorrow
Hi Brian,
I also noticed strobing with some footage I shot a couple of days ago. However ,I watched the same footage back today and the stobing was not nearly as bad as I remembered it? In fact it seems like it is hardly there at all. I am wondering if strobing is also perceptual? i.e. if we bring our attention towards it it will seem more intense or maybe I've lost the old plot, what do you guys think. Regards Greg C (slowly going gah gah) P.S. Strobing also seems more prominent in low light situations does this sound right? |
and low light?
Sorry to bug you guys again but i was just wondering. nate said that 'yes strobing can be perceptual', but Nate, is low light also an issue i.e. is it a combination of these two factors or is light not an issue?
Cheers, Greg C. |
Actually I didn't start noticing it until I began editing in FCP. Unles the camera movement went very slow I got motion blur, but then again the motion smooth was on. I will shoot some stuff with it on and off to see the difference.
For Manny & Brian,
Check out this article on how to calibrate broadcast monitors. http://www.execulink.com/~impact/bmonitor.htm |
Also you can use the THX routine on a television/flat panel in addition to a broadcast monitor. It's a good idea to get some blue glasses and the THX routine on DVD. In that case you can use any monitor that has the appropriate controls to achieve balance to view your work.
